Help Center/ Cloud Container Engine/ User Guide/ O&M/ Alarm Center/ Configuring Alarms in Alarm Center
Updated on 2026-09-21 GMT+08:00
Based on AOM, Alarm Center can quickly detect cluster faults and generate alarms to ensure service stability. Alarm Center provides built-in alarm rules, which free you from manually configuring alarm rules in AOM. These rules are established based on the extensive cluster O&M experience of the Huawei Cloud container team and can cover container service exceptions, key metric alarms of basic cluster resources, and metric alarms of applications in clusters to meet your routine O&M requirements.
  • The cluster version must be v1.17 or later.
  • Only Huawei Cloud accounts, HUAWEI IDs, or IAM users with the CCE Administrator or CCE FullAccess permissions can perform all operations in Alarm Center. IAM users with the CCE ReadOnlyAccess permissions can only view all resources.
Enabling Alarm Center
Alarm Center can be enabled for CCE standard and Turbo clusters.
  1. Click the cluster name to access the cluster console. In the navigation pane, choose Alarm Center.
  2. On the Alarm Rules tab, click Enable Alarm Center. In the window that slides out from the right, select one or more contact groups to manage subscription endpoints and receive alarm messages by contact group. If no contact group is available, create one by referring to Binding Contact Groups.
  3. Click OK.
    Metric alarm rules in Alarm Center rely on the Cloud Native Cluster Monitoring add-on to report metrics to AOM Prometheus instances. You need to enable Monitoring Center. If the add-on is not installed or connected to any AOM Prometheus instance, you cannot create these rules. For details about how to enable Monitoring Center, see Enabling Monitoring Center.
    The alarm rules that use the problem_gauge metric in Table 1 depend on the CCE Node Problem Detector add-on (CCE Node Problem Detector). To use related alarm rules, ensure that this add-on has been installed and is running normally.
    Event alarms in Table 1 depend on the Cloud Native Log Collection add-on. For details, see Cloud Native Log Collection.
Configuring Alarm Rules
After Alarm Center is enabled for CCE standard and Turbo clusters, you can configure and manage alarm rules.
  2. In the navigation pane, choose Alarm Center. Then, click the Alarm Rules tab and configure and manage alarm rules.
    By default, Alarm Center generates alarm rules for containers. The rules are intended for alarms including event alarms and metric alarms for exceptions. Alarm rules are classified into several sets. You can associate an alarm rule set with multiple contact groups and enable or disable alarm items. An alarm rule set consists of multiple alarm rules. An alarm rule corresponds to the check items for a single exception. Table 1 lists default alarm rules.
Table 1 Default alarm rules
Rule Type
Alarm Item
Alarm Type
Dependency Item
PromQL/Event Name
Load rule set
Abnormal pod
Check whether the pod is running normally.
Metric
sum(min_over_time(kube_pod_status_phase{phase=~"Pending|Unknown|Failed"}[10m]) and count_over_time(kube_pod_status_phase{phase=~"Pending|Unknown|Failed"}[10m]) > 18 )by (namespace,pod, phase, cluster_name, cluster) > 0
Frequent pod restarts
Check whether the pod frequently restarts.
Metric
increase(kube_pod_container_status_restarts_total[5m]) > 3
Unexpected number of Deployment replicas
Check whether the number of Deployment replicas is the same as the expected value.
Metric
(kube_deployment_spec_replicas != kube_deployment_status_replicas_available ) and ( changes(kube_deployment_status_replicas_updated[5m]) == 0)
Unexpected number of StatefulSet replicas
Check whether the number of StatefulSet replicas is the same as the expected value.
Metric
(kube_statefulset_status_replicas_ready != kube_statefulset_status_replicas) and (changes(kube_statefulset_status_replicas_updated[5m]) == 0)
Container CPU usage higher than 80%
Check whether the container CPU usage is higher than 80%.
Metric
100 * (sum(rate(container_cpu_usage_seconds_total{image!="", container!="POD"}[1m])) by (cluster_name,pod,node,namespace,container, cluster) / sum(kube_pod_container_resource_limits{resource="cpu"}) by (cluster_name,pod,node,namespace,container, cluster)) > 80
Container memory usage higher than 80%
Check whether the container memory usage is higher than 80%.
Metric
(sum(container_memory_working_set_bytes{image!="", container!="POD"}) BY (cluster_name, node,container, pod , namespace, cluster) / sum(container_spec_memory_limit_bytes > 0) BY (cluster_name, node, container, pod , namespace, cluster) * 100) > 80
Abnormal container
Check whether the container is running normally.
Metric
sum by (namespace, pod, container, cluster_name, cluster) (kube_pod_container_status_waiting_reason) > 0
Load balancer update failed
Check whether a load balancer is updated.
Event
N/A
Pod OOM
Check whether OOM occurs on the pod.
Event
CCE Node Problem Detector (1.18.41 or later)
Cloud Native Log Collection (1.3.2 or later)
PodOOMKilling
Node resource rule set
High usage of Kubernetes PV
Check whether the PV usage on a node is too high.
Metric
(kubelet_volume_stats_available_bytes{job="kubelet"} / kubelet_volume_stats_capacity_bytes{job="kubelet"}) < 0.03 and kubelet_volume_stats_used_bytes{job="kubelet"} > 0
Abnormal Kubernetes PVC
Check whether the PVC is normal.
Metric
kube_persistentvolumeclaim_status_phase{phase=~"Failed|Pending|Lost"} > 0
Check whether the PV is normal.
Metric
kube_persistentvolume_status_phase{phase=~"Failed|Pending"} > 0
Node CPU usage higher than 80%
Check whether the node CPU usage is higher than 80%.
Metric
100 - (avg by(node, cluster_name, cluster) (rate(node_cpu_seconds_total{mode="idle"}[2m])) * 100) > 80
Available node memory less than 10%
Check whether the available node memory is less than 10%.
Metric
node_memory_MemAvailable_bytes / node_memory_MemTotal_bytes * 100 < 10
Available node disk space less than 10%
Check whether the available node disk space is less than 10%.
Metric
avg((node_filesystem_avail_bytes * 100) / node_filesystem_size_bytes) by (device, node, cluster_name, cluster) < 10
Insufficient node disk space
Check whether the node disk space is sufficient.
Event
N/A
emptyDir storage pool error
Check whether the node's EV storage pool is functional.
Metric
problem_gauge{type="EmptyDirVolumeGroupStatusError"} >= 1
Insufficient node memory
Check whether the overall node memory is sufficient.
Metric
problem_gauge{type="MemoryProblem"} >= 1
PV storage pool error
Check whether the node's PV storage pool is functional.
Metric
problem_gauge{type="LocalPvVolumeGroupStatusError"} >= 1
Abnormal node mount point
Check whether the node's mount point is available.
Metric
problem_gauge{type="MountPointProblem"} >= 1
Insufficient node file handles
Check whether the FD file handles are sufficient.
Metric
problem_gauge{type="FDProblem"} >= 1
Node disk I/O suspension
Check whether I/O suspension occurs on the node disk.
Metric
problem_gauge{type="DiskHung"} >= 1
Node disk read-only
Check whether the node disk is read-only.
Metric
problem_gauge{type="DiskReadonly"} >= 1
Abnormal node disk
Check the usage of the node's system disk and CCE data disks (including Docker and kubelet logical disks).
Metric
problem_gauge{type="DiskProblem"} >= 1
Slow node disk I/O
Check whether slow I/O occurs on the node disk.
Metric
problem_gauge{type="DiskSlow"} >= 1
Insufficient node PIDs
Check whether the PIDs are sufficient.
Metric
problem_gauge{type="PIDProblem"} >= 1
Node conntrack table full
Check whether the node's conntrack table space is sufficient.
Metric
problem_gauge{type="ConntrackFullProblem"} >= 1
Node status rule set
ResolvConf error
Check whether the ResolvConf configuration file is available.
Metric
problem_gauge{type="ResolvConfFileProblem"} >= 1
Abnormal node CNI component
Check whether the CNI component of the node is running properly.
Metric
problem_gauge{type="CNIProblem"} >= 1
Abnormal node CRI component
Check the running of the key component CRI (Docker or containerd).
Metric
problem_gauge{type="CRIProblem"} >= 1
Node kube-proxy error
Check whether kube-proxy is running properly.
Metric
problem_gauge{type="KUBEPROXYProblem"} >= 1
Abnormal node kubelet
Check whether kubelet is running normally.
Metric
problem_gauge{type="KUBELETProblem"} >= 1
Scheduled event on the node
Check whether there is a scheduled event on the node.
Metric
problem_gauge{type="ScheduledEvent"} >= 1
Unstable node status
Check whether the node status alternates between normal and abnormal.
Metric
sum(changes(kube_node_status_condition{status="true",condition="Ready"}[15m])) by (cluster_name, node, cluster) > 2
Frequent node containerd restarts
Check whether containerd frequently restarts.
Metric
problem_gauge{type="FrequentContainerdRestart"} >= 1
Node task suspended
Check whether a task is suspended on the node.
Event
TaskHung
Incorrect node storage pool configuration
Check whether the node's EV and PV storage pools are correctly configured.
Event
InvalidStoragePool
Abnormal node
Check whether the node is running normally.
Event
NodeNotReady
Abnormal node process D
Check whether there is a D state process on the node.
Metric
problem_gauge{type="ProcessD"} >= 1
Abnormal node process Z
Check whether there is a Z state process on the node.
Metric
problem_gauge{type="ProcessZ"} >= 1
Frequent node CRI restarts
Check whether CRI frequently restarts.
Metric
problem_gauge{type="FrequentCRIRestart"} >= 1
Frequent node Docker restarts
Check whether Docker frequently restarts.
Metric
problem_gauge{type="FrequentDockerRestart"} >= 1
Frequent node kubelet restarts
Check whether kubelet frequently restarts.
Metric
problem_gauge{type="FrequentKubeletRestart"} >= 1
Node NTP service error
Check whether the node clock synchronization service ntpd or chronyd is running properly.
Metric
problem_gauge{type="NTPProblem"} >= 1
Processes forcibly stopped due to node OOM
Check whether an OOM event occurred on the node.
Event
OOMKilling
Node scaling rule set
Node pool resources sold out
Check whether the node pool resources are sufficient.
Event
NodePoolSoldOut
Node scale-out timed out
Check whether scaling out nodes in the node pool timed out.
Event
ScaleUpTimedOut
Node pool scale-out failed
Check whether an error occurred during a node pool scale-out.
Event
FailedToScaleUpGroup
Node pool scale-in failed
Check whether an error occurred during a node pool scale-in.
Event
ScaleDownFailed
Cluster status rule set
Unavailable cluster
Check whether the cluster is available.
For details, see How Do I Locate the Fault When a Cluster Is Unavailable?
Event
N/A
An alarm rule can be bound to a maximum of five contact groups.
Contact groups use Simple Message Notification (SMN) to enable communication between message publishers and subscribers. A contact group contains one or more endpoints. You can attach an alarm rule to a contact group to manage endpoints that have subscribed to alarm messages.
  2. In the navigation pane, choose Alarm Center. Then, click the Default Contact Groups tab.
  3. Click Bind Contact Group. You can select a contact group created in SMN or create a contact group. The parameters for creating a contact group are described as follows:
    • Contact Group Name: Enter the name of the contact group, which cannot be changed after the contact group is created. The name can contain 1 to 255 characters and must start with a letter or digit. Only letters, digits, hyphens (-), and underscores (_) are allowed.
    • Alarm Message Display Name: Enter the title of the message received by the specified subscription endpoint. For example, if you set Type to Email and specify a display name, the name you specified will be displayed as the alarm message sender. If no alarm message display name is specified, the sender will be username@example.com. The alarm message display name can be changed after a contact group is created.
    • Endpoints: Add one or more endpoints to receive alarm messages.
      Endpoint Type
      Endpoint
      Security Setting
      SMS
      Enter a valid mobile number to receive alarm messages.
      N/A
      Email
      Enter a valid email address to receive alarm messages.
      N/A
      DingTalk chatbot
      Enter the URL of the DingTalk chatbot to receive alarm messages.
      Select one or more of the following security settings:
      • Secret: Obtain the secret from the security context of the DingTalk chatbot.
      • Custom keyword: Select a keyword from the security context of the DingTalk chatbot.
      Lark chatbot
      Enter the URL of the Lark chatbot to receive alarm messages.
      • Secret: Obtain the secret from the security context of the Lark chatbot.
      • Custom keyword: Select a keyword from the security context of the Lark chatbot.
      WeCom chatbot
      Enter the URL of the WeCom chatbot to receive alarm messages.
      N/A
  4. Click OK.
    You will be redirected to the contact group list. The subscription endpoint is in the Unconfirmed state. Send a subscription request to the endpoint to verify the validity of the endpoint.
  5. Click Request Confirmation in the Operation column to send a subscription request to the endpoint. After the endpoint receives and confirms the request, the subscription endpoint status changes to Confirmed.
Viewing Alarms
You can view the latest historical alarms on the Alarms tab.
  2. In the navigation pane, choose Alarm Center. Then, click the Alarms tab.
    By default, all alarms to be cleared are displayed in the list. You can query alarms by alarm keyword, alarm severity, or alarm time. In addition, you can view the distribution of alarms that meet the specified criteria in different periods.
    If an alarm to be cleared is not triggered within 10 minutes, the alarm is considered cleared by default and converted to a historical alarm. If you confirm that an alarm has been handled in advance, you can also click Clear in the Operation column. You can view this cleared alarm in the historical alarm list.
    Figure 1 Querying alarms
