Updated on 2026-09-21 GMT+08:00
Enabling Monitoring Center
After Monitoring Center is enabled for a cluster, the Cloud Native Cluster Monitoring add-on used to collect metrics is installed. Cluster metrics are collected and reported to AOM instances. This section describes how to enable Monitoring Center.
  • After Monitoring Center is enabled, cluster metrics are reported to the selected AOM instance. Basic metrics can be monitored for free, but custom metrics are billed based on the standard pricing of AOM. For details, see AOM Pricing Details.
  • The Cloud Native Cluster Monitoring add-on consumes cluster resources. Ensure that there are required cluster resources for installing the add-on. For details about the resource consumption, go to the add-on details page.
You have an account in the admin user group to delegate CCE and its dependent services.
The authorization dialog box is automatically displayed on the Monitoring Center page. After you confirm the authorization, the system automatically completes the authorization. For details about permission types, see Agency Permissions.
  • The cluster version must be v1.17 or later.
  • Before using Monitoring Center, you need to use an account in the admin user group to delegate CCE and its dependent services. After the authorization is complete, users with the CCE Administrator role or CCE FullAccess permission can perform all operations on Monitoring Center. Users with the CCE ReadOnlyAccess permission can view all resource information but cannot perform any operations.
  • Self-built Prometheus or the Prometheus add-on (Prometheus (EOM)) is not installed in the cluster.
  • Enabling Monitoring Center during cluster purchase
    1. Log in to the CCE console and purchase a cluster.
    2. On the Select Add-on page, select the Cloud Native Cluster Monitoring add-on.
    3. On the Add-on Configuration page, select the AOM instance to be interconnected with the add-on. If there is no access code, create one first.
      Figure 1 Enabling cluster monitoring
    4. After the cluster is created, create a node on the Nodes tab. After the node is created, the Cloud Native Cluster Monitoring add-on will be automatically deployed on the node.
  • Enabling Monitoring Center on the Monitoring Center page
    1. Click the cluster name to access the cluster console. In the navigation pane, choose Monitoring Center.
    2. Check whether there is self-built Prometheus in the cluster. The Cloud Native Cluster Monitoring add-on installed when Monitoring Center is enabled may conflict with self-built Prometheus.
      If your cluster already has self-built Prometheus, you can select Compatibility Mode to enable the compatibility mode. The Cloud Native Cluster Monitoring add-on will be installed in the cce-monitoring namespace and works with self-built Prometheus. However, there are some restrictions on the compatibility mode. For details, see Cloud Native Cluster Monitoring Is Compatible with Self-Built Prometheus.
      Figure 2 Compatibility mode
    3. Click Enable and select the AOM instance that metrics are reported to.
      Figure 3 Enabling Monitoring Center
    4. Wait for 3 to 5 minutes until the monitoring data is reported to the AOM instance.
      The functions of Monitoring Center are available.
  • Enabling Monitoring Center on the Add-ons page
    1. Click the cluster name to access the cluster console. In the navigation pane, choose Add-ons.
    2. Select the Cloud Native Cluster Monitoring add-on and click Install.
    3. Enable Reporting Monitoring Data to AOM. The other two data storage configuration items can be enabled as needed.
      Figure 4 Installing the Cloud Native Cluster Monitoring add-on
To disable Monitoring Center, uninstall the Cloud Native Cluster Monitoring add-on on the Add-ons page or disable the option for interconnecting with AOM.
FAQ
  • Failed to enable Monitoring Center because the add-on is abnormal.
    Solution: Go to the Add-ons page to view the list of installed add-ons. Click the name of the Cloud Native Cluster Monitoring add-on to go to its details page. On the Pods tab, view the events of abnormal pods and locate faults based on the error information.
    Figure 5 Abnormal add-on
  • There is no data on the Monitoring Center page.
    Solution:
    1. Go to the Add-ons page to view the list of installed add-ons. Click the name of the Cloud Native Cluster Monitoring add-on to go to its details page. On the Pods tab, check whether the Prometheus instance is running normally. If the Prometheus instance is not running normally, view the events of pods to obtain the error information.
      For example, if "0/6 nodes are available: 1 Insufficient cpu, 2 node(s) had taint {cie.manage: proxy}, that the pod didn't tolerate, 3 node(s) had taint {node.kubernetes.io/unreachable: }, that the pod didn't tolerate" is displayed, the CPU of one node is insufficient and the remaining five nodes are marked with taints. As a result, pods cannot be scheduled.
    2. If the add-on is normal, you can query the logs of the Prometheus instance and check whether the logs contain error information. Error information related to remote_write indicates that metrics fail to be reported. In this case, check whether the network for reporting the metrics is normal.
