Cloud Native Cluster Monitoring Is Compatible with Self-Built Prometheus
Compatibility Mode of Cloud Native Cluster Monitoring
- If you have deployed Prometheus and your Prometheus is open-source and has not been deeply customized or integrated with your monitoring system, you are advised to uninstall it and use the Cloud Native Cluster Monitoring add-on instead. By doing so, you do not need to enable Compatibility Mode.
      To uninstall your self-built Prometheus, ensure that all workloads of your self-built Prometheus and all CRDs ending with monitoring.coreos.com are deleted. For details, see How Do I Delete Self-Built Prometheus?.
 - If your self-built Prometheus cannot be uninstalled and you need to use functions such as Cost Insights and Monitoring Center, you can enable Compatibility Mode when your self-built Prometheus meets Compatibility Requirements. For details, see Enabling Monitoring Center.
      The compatibility mode does not support all functions of the Cloud Native Cluster Monitoring add-on. For details, see Restrictions on the Compatibility Mode.
Ensure that your self-built Prometheus meets the following requirements, or it cannot run normally.
- If your Prometheus is not based on kube-prometheus of the Operator community, the compatibility requirements are met.
 - If your Prometheus is based on kube-prometheus of the Operator community, the prometheuses.monitoring.coreos.com version must be 0.8.0 or later.
You can run the following command in the cluster to check the version:
kubectl get crd prometheuses.monitoring.coreos.com -oyaml | grep controller-gen.kubebuilder.io/version
If the following information is displayed, the compatibility requirements are met:
Error from server (NotFound): customresourcedefinitions.apiextensions.k8s.io "prometheuses.monitoring.coreos.com" not found
If the following information is displayed and the version is 0.8.0 or later, the compatibility requirements are met:
controller-gen.kubebuilder.io/version: v0.9.2
- In compatibility mode, the Cloud Native Cluster Monitoring add-on is installed in the cce-monitoring namespace. By default, the ServiceMonitor and PodMonitor of another namespace are not identified.
 - The Cloud Native Cluster Monitoring add-on can only be deployed without local data storage.
 - You cannot disable compatibility mode once it is enabled. To use the normal mode, you can uninstall the Cloud Native Cluster Monitoring add-on first and install it again.
 - Currently, cost optimization is not supported.
 - Currently, metrics discarding on the AOM page is not supported.
 - Currently, the ServiceMonitor and PodMonitor cannot be started or stopped on the AOM page.
- Delete all workloads, services, and other resources related to self-built Prometheus, such as DaemonSets, Deployments, StatefulSets, and Services. Generally, these resources are in the monitoring namespace. Replace it with the actual namespace used during the add-on installation.
 - Query all CRDs ending with monitoring.coreos.com.
kubectl get crd | grep monitoring.coreos.com | awk '{print $1}' | xargsIf the command output is empty, no further action is required.
 - Delete all CRDs ending with monitoring.coreos.com.
kubectl delete crd $(kubectl get crd | grep monitoring.coreos.com | awk '{print $1}' | xargs)
