Updated on 2026-09-21 GMT+08:00
VPA
The VPA add-on supports vertical pod autoscaling. It automates the adjustment of CPU and memory resource requests for pods based on their historical resource usage.
For details about the open-source Vertical Pod Autoscaler, see autoscaler.
Overview
VPA collects and analyzes resource metrics for each container, adjusts the requested resources based on actual usage, and maintains the ratio of resource limit to request before and after the adjustment. VPA can increase or decrease CPU and memory resources as needed.
The rules are as follows:
  • VPA generates the CPU and memory resource recommendations using the data collected by the Metrics API.
  • VPA, in theory, recommends a minimum of 250 MiB of memory for each pod and 250 MiB divided by the number of containers in the pod for each container. It also recommends a minimum of 25m vCPUs for each pod and 25m divided by the number of containers in the pod for each container.
    When setting up a VPA, you can establish the minimum and maximum number of elastic resources in containers by configuring the containerPolicies field.
  • If a container has both resource request and limit configured, VPA will provide resource recommendations. It will adjust the requested resources of the container to match the recommendations and generate recommended resource limit based on the ratio of the original resource request to the limit set during the container's initial creation.
    Assume that the requested vCPUs of a container are 100m and the limit is 200m (with a ratio of 1:2). If VPA recommends a requested vCPU of 80m, the container's vCPU limit will be 160m.
  • VPA ensures its recommendations align with other resource limits. If the VPA recommendations conflict with a resource limit, they will not be adjusted to fit the limit. This means that the resource configuration suggested by VPA may go beyond other resource limits.
    Assume that the requested memory of a namespace cannot exceed 2 GiB. If VPA recommends a high memory configuration for a pod in that namespace, the total memory requested by the namespace may exceed 2 GiB after the pod's resource configuration is updated. This means the pod will not be scheduled.
  • VPA introduces the InPlaceOrRecreate policy, which first attempts to adjust a pod's requested resources in place without restarting it. Pod recreation is triggered only when necessary, such as, when an in-place upgrade fails, minimizing service interruption. During an in-place upgrade, all containers in the pod are updated simultaneously. Partial updates that change only some containers are not supported.
    After the in-place upgrade feature is enabled, VPA will try to perform in-place updates in scenarios where:
    • Containers experience rapid OOM events.
    • The requested resources exceed the recommended range.
    • A pod has been running for a long time (over 12 hours by default), and the difference between its current and recommended resource values exceeds 10%.
    Although in-place upgrades reduce service downtime, some pods may not support in-place upgrades during resizing. In such cases, VPA falls back to the Recreate policy, which still cannot guarantee zero interruption.
    An in-place upgrade may fail, causing VPA to fall back to the Recreate policy, in the following situations:
    • A pod's in-place upgrade status becomes Infeasible (for example, the requested resources exceed the node capacity).
    • A pod's in-place upgrade status remains in Deferred for more than 5 minutes.
    • A pod upgrade takes longer than 1 hour.
    • The resource adjustment causes a QoS class change for a pod (for example, from BestEffort to Guaranteed).
    • If a pod's resizePolicy is set to PreferNoRestart (the default), the memory limit cannot be decreased.
Installing the Add-on
  2. In the navigation pane, choose Add-ons. Locate VPA on the right and click Install.
  3. On the Install Add-on page, configure the specifications as needed.
    • If you selected Preset, you can choose between Small, Medium, or Large based on the number of pods in the cluster. The system will automatically set the number of add-on pods and resource quotas according to the preset specifications. You can see the configurations on the console.
    • If you selected Custom, you can adjust the number of pods and resource quotas as needed. High availability is not possible with a single pod. If an error occurs on the node where the add-on pod runs, the add-on will fail.
  4. Configure deployment policies for the add-on pods.
    • Scheduling policies do not take effect on the DaemonSet pods of the add-on.
    • When configuring multi-AZ deployment or node affinity, ensure that there are nodes meeting the scheduling policy and that resources are sufficient in the cluster. Otherwise, the add-on pods cannot run.
    Table 1 Configurations for add-on scheduling
    Multi-AZ Deployment
    • Preferred: Deployment pods of the add-on will be preferentially scheduled to nodes in different AZs. If all the nodes in the cluster are deployed in the same AZ, the pods will be scheduled to different nodes in that AZ.
    • Forcible: Deployment pods of the add-on are forcibly scheduled to nodes in different AZs. There can be at most one pod in each AZ. If the cluster's nodes do not span multiple AZs, some add-on pods will remain unscheduled and fail to run. If a node is faulty, the add-on pods on it may fail to be migrated.
    Node Affinity
    • Not configured: Node affinity is disabled for the add-on pods.
    • Specify node: Specify the nodes where the add-on pods are deployed. If you do not specify the nodes, the add-on pods will be randomly scheduled based on the default cluster scheduling policy.
    • Specify node pool: Specify the node pool where the add-on pods are deployed. If you do not specify the node pools, the add-on pods will be randomly scheduled based on the default cluster scheduling policy.
    • Customize affinity: Enter the labels of the nodes where the add-on pods are to be deployed for more flexible scheduling policies. If you do not specify node labels, the add-on pods will be randomly scheduled based on the default cluster scheduling policy.
      If multiple custom affinity policies are configured, ensure that there are nodes that meet all the affinity policies in the cluster. Otherwise, the add-on pods cannot run.
    Toleration
    Using both taints and tolerations enables (but does not require) the add-on's Deployment pods to be scheduled on nodes with matching taints, and allows control over pod eviction policies when host nodes are tainted.
    The add-on applies default tolerations for the node.kubernetes.io/not-ready and node.kubernetes.io/unreachable taints. The toleration time window is 60 seconds.
    For details, see Configuring Tolerance Policies.
  5. Click Install.
Components
Table 2 Add-on components
Component
Resource Type
vpa-admission-controller
Change the resource requests for a pod to the recommendations generated by the VPA when the pod is created.
Deployment
vpa-recommender
Collect the actual CPU and memory metrics of a pod and generate resource recommendations for the requested resources based on the actual resource usage.
Deployment
vpa-updater
Evict a pod whose actual resource requests are different from the VPA recommendations and trigger pod recreation so that the resource recommendations can apply to the new pod.
Deployment
Helpful Links
  • After the add-on is installed, you can create VPA policies to automatically adjust the CPU and memory requested by pods. For details, see Creating a VPA Policy.
  • For details about how VPA works, see How VPA Works.
Release History
Table 3 VPA updates
Add-on Version
Supported Cluster Version
New Feature
Community Version
1.1.13
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
v1.36
Updated the add-on to its community version 1.6.0.
1.6.0
1.1.8
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
v1.36
Supported CCE clusters v1.36.
1.5.1
1.1.3
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
v1.35
Supported CCE clusters v1.35.
1.5.1
1.1.2
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
Supported in-place pod upgrades.
1.5.1
1.0.39
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
v1.34
Supported CCE clusters v1.34.
1.3.0
1.0.38
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
Fixed some issues.
1.3.0
1.0.27
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
v1.33
Supported CCE clusters v1.33.
1.3.0
1.0.25
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
v1.32
Supported CCE clusters v1.32.
1.3.0
1.0.11
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
Updated the add-on to its community version 1.3.0.
1.3.0
1.0.6
v1.25
v1.27
v1.28
v1.29
v1.30
v1.31
Supported CCE clusters v1.31.
1.1.2
1.0.4
v1.25
v1.27
v1.28
v1.29
v1.30
VPA is now available.
1.1.2
