Managing Workload Scaling Policies
After an HPA or CustomedHPA policy is created, you can update and delete the policy, as well as edit the YAML file.
Checking an HPA Policy
You can view the rules, status, and events of an HPA policy and handle exceptions based on the error information displayed.
- In the navigation pane, choose Policies. On the page displayed, click the HPA Policies tab and then
next to the target HPA policy.
- In the expanded area, choose View Events in the Operation column. If the policy malfunctions, locate and rectify the fault based on the error message displayed on the page.
You can also view the created HPA policy on the workload details page.
- In the navigation pane, choose Workloads. Click the workload name to view its details.
- On the workload details page, switch to the Auto Scaling tab page to view the HPA policies or CustomedHPA policies. You can also view the scaling policies you configured on the Policies page.
Table 1 Event types and names Event Type
Event Name
Normal
SuccessfulRescale
The scaling is performed successfully.
Abnormal
InvalidTargetRange
Invalid target range.
InvalidSelector
Invalid selector.
FailedGetObjectMetric
Objects fail to be obtained.
FailedGetPodsMetric
Pods fail to be obtained.
FailedGetResourceMetric
Resources fail to be obtained.
FailedGetExternalMetric
External metrics fail to be obtained.
InvalidMetricSourceType
Invalid metric source type.
FailedConvertHPA
HPA conversion failed.
FailedGetScale
The scale fails to be obtained.
FailedComputeMetricsReplicas
Failed to calculate metric-defined replicas.
FailedGetScaleWindow
Failed to obtain ScaleWindow.
FailedRescale
Failed to scale the service.
Viewing a CustomedHPA Policy
You can view the rules and latest status of a CustomedHPA policy and rectify faults based on the error information displayed.
- In the navigation pane, choose Policies. On the page displayed, click the CustomHPA Policies tab and then
next to the target CustomHPA policy.
- In the expanded area, if the policy is abnormal on the Rules tab page, click Details in Latest Status and locate the fault based on the information displayed.
Editing an HPA or CustomedHPA Policy
An HPA policy is used as an example.
- In the navigation pane, choose Policies. On the page displayed, click the HPA Policies tab. Locate the row containing the target policy and choose More > Edit in the Operation column.
- On the Edit HPA Policy page, configure policy parameters listed in Table 1.
- Click OK.
Editing the YAML File (HPA Policy)
- In the navigation pane, choose Policies. On the page displayed, click the HPA Policies tab. Locate the row containing the target policy and click Edit YAML in the Operation column.
- In the dialog box displayed, edit or download the YAML file.
Viewing the YAML File (CustomedHPA Policy)
- In the navigation pane, choose Policies. On the page displayed, click the CustomedHPA Policies tab, locate the row containing the target policy, and choose More > View YAML in the Operation column.
- In the dialog box displayed, copy and download the YAML file but you are not allowed to modify it.
- Click the close button in the upper right corner.
Deleting an HPA or CustomedHPA Policy
- In the navigation pane, choose Policies. Choose More > Delete in the Operation column of the target policy.
- In the dialog box displayed, click Yes.
