Situation Awareness
Help Center/ Cloud Container Engine/ User Guide (Paris Regions)/ Getting Started/ Creating a Deployment (Nginx) from an Image
Updated on 2023-07-06 GMT+08:00
You can use images to quickly create a single-pod workload that can be accessed from public networks. This section describes how to use CCE to quickly deploy an Nginx application and manage its life cycle.
  • The Nginx image has been pushed to SWR.
  • You have created a CCE cluster that contains a node with 4 vCPUs and 8 GB memory. The node has an elastic IP address (EIP).
  • A cluster is a logical group of cloud servers that run workloads. Each cloud server is a node in the cluster.
  • For details on how to create a cluster, see Creating a Kubernetes Cluster.
Nginx Overview
Nginx is a lightweight web server. On CCE, you can quickly set up a Nginx web server.
This section uses the Nginx application as an example to describe how to create a workload. The creation takes about 5 minutes.
After Nginx is created successfully, you can access the Nginx web page.
Figure 1 Nginx web page
The following is the procedure for creating a containerized workload from a container image.
  1. Log in to the CCE console.
  2. Choose the target cluster.
  3. In the navigation pane, choose Workloads. Then, click Create Workload.
  4. Configure the following parameters and retain the default value for other parameters:
    Basic Info
    • Workload Type: Select Deployment.
    • Workload Name: Set it to nginx.
    • Namespace: Select default.
    • Pods: Set the quantity of pods to 1.
    Container Settings
    In the Basic Info area, click Select Image. In the dialog box displayed, select Open Source Images, search for nginx, and select the nginx image.
    Service Settings
    Click the plus sign (+) to create a Service for accessing the workload from an external network. In this example, create a LoadBalancer Service. Set the following parameters:
    • Service Name: name of the Service exposed to external networks. In this example, the Service name is nginx.
    • Service Type: Select LoadBalancer.
    • Service Affinity: Retain the default value.
    • Load Balancer: If a load balancer is available, select an existing load balancer. If not, choose Auto create to create one on the ELB console.
    • Port:
      • Protocol: Select TCP.
      • Service Port: Set this parameter to 8080, which is mapped to the container port.
      • Container Port: port on which the application listens. For containers created using the Nginx image, set this parameter to 80. For other applications, set this parameter to the port of the application.
  5. Click Create Workload.
    Wait until the workload is created.
    The created Deployment will be displayed on the Deployments page.
Accessing Nginx
  1. Obtain the external access address of Nginx.
    Click the Nginx workload to enter its details page. On the Access Mode tab page, you can view the IP address of Nginx. The public IP address is the external access address.
  2. Enter the external access address in the address box of a browser. The following shows the welcome page if you successfully access the workload.
    Figure 2 Accessing Nginx
