Help Center/
      Cloud Container Engine/
        User Guide (Ankara Region)/
        Clusters/
        Upgrading a Cluster/
        Troubleshooting for Pre-upgrade Check Exceptions/
      containerd.sock
        Updated on 2024-12-18 GMT+08:00
containerd.sock
Check Items
Check whether the containerd.sock file exists on the node. This file affects the startup of container runtime in the Euler OS.
Solution
Scenario: The Docker used by the node is the customized Euler-docker.
- Log in to the node.
 - Run the rpm -qa | grep docker | grep euleros command. If the command output is not empty, the Docker used on the node is Euler-docker.
 - Run the ls /run/containerd/containerd.sock command. If the file exists, Docker startup will fail.
 - Run the rm -rf /run/containerd/containerd.sock command and perform the cluster upgrade check again.
   Parent topic: Troubleshooting for Pre-upgrade Check Exceptions
