Updated on 2026-04-07 GMT+08:00
Why Can't a Pod Be Scheduled to a Node?
  1. Check whether the node and Docker are normal. For details, see Check Item 7: Whether Internal Components Are Normal.
  2. If the node and Docker are normal, check whether an affinity policy is configured for the pod. For details, see Check Item 3: Affinity and Anti-Affinity Configuration of the Workload.
  3. Check whether the resources on the node are sufficient. If the resources are insufficient, expand the capacity or add nodes.
