Configuring HTTPS Backend Services for an Nginx Ingress
Ingress can function as a proxy for backend services using different protocols. By default, the backend proxy channel of an ingress is an HTTP channel. To create an HTTPS channel, add the following configuration to the annotations field:
nginx.ingress.kubernetes.io/backend-protocol: "HTTPS"
An ingress configuration example is as follows:
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Create a YAML file named ingress-test.yaml. The file name can be customized.
vi ingress-test.yaml
For clusters v1.23 or later:apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test namespace: default annotations: nginx.ingress.kubernetes.io/backend-protocol: "HTTPS" spec: tls: - secretName: ingress-test-secret # Replace it with your TLS key certificate. rules: - host: '' http: paths: - path: '/' backend: service: name: <your_service_name> # Replace it with your target Service name. port: number: <your_service_port> # Replace it with your target Service port. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: nginxFor clusters v1.21 or earlier:apiVersion: networking.k8s.io/v1beta1 kind: Ingress metadata: name: ingress-test namespace: default annotations: kubernetes.io/ingress.class: nginx nginx.ingress.kubernetes.io/backend-protocol: "HTTPS" spec: tls: - secretName: ingress-test-secret # Replace it with your TLS key certificate. rules: - host: '' http: paths: - path: '/' backend: serviceName: <your_service_name> # Replace it with your target Service name. servicePort: <your_service_port> # Replace it with your target Service port. - Create an ingress.
If information similar to the following is displayed, the ingress has been created:
ingress.networking.k8s.io/ingress-test created
- Check the created ingress.
kubectl get ingress
NAME CLASS HOSTS ADDRESS PORTS AGE ingress-test nginx * 121.**.**.** 80 10s
