Help Center>
Cloud Container Engine>
User Guide (Paris Regions)>
Clusters>
Upgrading a Cluster>
Troubleshooting for Pre-upgrade Check Exceptions>
Health of Master Node Components
Updated on 2024-01-26 GMT+08:00
Check Item
Check whether the Kubernetes, container runtime, and network components of the master nodes are healthy.
Solution
If a master node component malfunctions, contact technical support.
Parent topic: Troubleshooting for Pre-upgrade Check Exceptions
