Help Center/
Cloud Container Engine/
User Guide (Kuala Lumpur Region)/
Network/
Cluster Network Settings/
Adding a Container CIDR Block for a Cluster
Updated on 2024-07-27 GMT+08:00
If the container CIDR block set during CCE cluster creation is insufficient, you can add a container CIDR block for the cluster.
- This function applies to CCE standard clusters of v1.19 or later, but not to clusters using container tunnel networking.
- The container CIDR block or container subnet cannot be deleted after being added. Exercise caution when performing this operation.
Adding a Container CIDR Block for a CCE Standard Cluster
- On the Overview page, locate the Networking Configuration area and click Add.
- Configure the container CIDR block to be added. You can click
to add multiple container CIDR blocks at a time.
New container CIDR blocks cannot conflict with service CIDR blocks, VPC CIDR blocks, and existing container CIDR blocks.
- Click OK.
Parent topic: Cluster Network Settings
