Using OBS Buckets Across Regions
By default, a pod can use OBS buckets only in the same region. CCE allows a workload to use OBS buckets across regions, which can improve resource utilization in some scenarios, but may also result in a higher latency.
Notes and Constraints
- The CCE Container Storage (Everest) add-on version must be 1.2.42 or later.
- The node to which the storage is mounted must be able to access OBS buckets. Generally, the Internet or Direct Connect is used to access OBS buckets across regions. You can ping the endpoint of OBS on the node where OBS is located to check whether OBS is accessible.
- Only PVs can use OBS buckets across regions, and then are bound to PVCs. The PV reclaim policy must be Retain. StorageClass cannot be used to dynamically create PVCs for using OBS buckets across regions.
- Create the paas-obs-endpoint ConfigMap and configure the region and endpoint of OBS.
The ConfigMap name is fixed to paas-obs-endpoint, and the namespace is fixed to kube-system.
Region names and endpoints are in key-value pairs. Replace <region_name> and <endpoint_address> with specific values. Use commas (,) to separate multiple values.
For details about the value of region, see Regions and Endpoints.
Example: {"ap-southeast-1": "https://obs.ap-southeast-1.myhuaweicloud.com:443", "ap-southeast-3": "https://obs.ap-southeast-3.myhuaweicloud.com:443"}
apiVersion: v1 kind: ConfigMap metadata: name: paas-obs-endpoint # The value must be paas-obs-endpoint. namespace: kube-system # The value must be kube-system. data: obs-endpoint: | {"<region_name>": "<endpoint_address>"}
- Create a PV.
Set everest.io/region to the region where OBS is located.
kind: PersistentVolume apiVersion: v1 metadata: name: testing-abc annotations: pv.kubernetes.io/bound-by-controller: 'yes' pv.kubernetes.io/provisioned-by: everest-csi-provisioner spec: capacity: storage: 1Gi csi: driver: obs.csi.everest.io volumeHandle: testing-abc # OBS bucket name fsType: s3fs # obsfs indicates a parallel file system, and s3fs indicates an OBS bucket. volumeAttributes: everest.io/obs-volume-type: STANDARD everest.io/region: <region_name> # Region where the OBS bucket resides. Replace it with a specific value. storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner nodePublishSecretRef: # AK/SK used for mounting an OBS bucket name: test-user namespace: default accessModes: - ReadWriteMany persistentVolumeReclaimPolicy: Retain # The value must be Retain. storageClassName: csi-obs volumeMode: Filesystem
nodePublishSecretRef is the access key (AK/SK) used for mounting the object storage volume. Use the AK/SK to create a secret, which will be used when creating a PV. For details, see Using a Custom Access Key (AK/SK) to Mount an OBS Volume.
- Create a PVC.
apiVersion: v1 kind: PersistentVolumeClaim metadata: name: pvc-test-abc namespace: default annotations: everest.io/obs-volume-type: STANDARD # Bucket type, which can be STANDARD or WARM when an OBS bucket is used csi.storage.k8s.io/fstype: s3fs # File type. obsfs indicates a parallel file system, and s3fs indicates an OBS bucket. volume.beta.kubernetes.io/storage-provisioner: everest-csi-provisioner spec: accessModes: - ReadWriteMany # The value must be ReadWriteMany for object storage. resources: requests: storage: 1Gi # Storage capacity of a PVC. This parameter is valid only for verification (fixed to 1, cannot be empty or 0). The value setting does not take effect for OBS buckets. storageClassName: csi-obs # StorageClass name. For object storage, the value is fixed at csi-obs. volumeName: testing-abc # PV name
- Create a workload, select the PVC in the data storage option of the container settings, and add the created PVC. If the workload is successfully created, the OBS bucket can be used across regions.
apiVersion: apps/v1 kind: Deployment metadata: name: obs-deployment-example # Workload name namespace: default spec: replicas: 1 selector: matchLabels: app: obs-deployment-example template: metadata: labels: app: obs-deployment-example spec: containers: - image: nginx name: container-0 volumeMounts: - mountPath: /tmp # Mount path name: pvc-obs-example restartPolicy: Always imagePullSecrets: - name: default-secret volumes: - name: pvc-obs-example persistentVolumeClaim: claimName: pvc-test-abc # PVC name
