Help Center/ Cloud Container Engine/ User Guide/ Nodes/ Management Nodes/ Modifying the Auto-Renewal Configuration of a Yearly/Monthly Node
Updated on 2026-09-21 GMT+08:00
After purchasing yearly/monthly nodes, you can enable auto-renewal for them or modify the existing auto-renewal configuration as needed.
Enabling Auto-Renewal
  2. In the navigation pane, choose Nodes and switch to the Nodes tab page.
  3. Choose More > Enable Auto-Renewal in the Operation column of a yearly/monthly node. You can also select multiple nodes at a time. To do so, choose More > Enable Auto-Renewal in the function bar on the top of the page. In the displayed dialog box, confirm the nodes for which auto-renewal is to be enabled.
  4. On the Enable Auto-Renewal page, configure auto-renewal parameters.
    • New Auto-Renew Period: Configure the duration of each renewal. The minimum duration of each renewal is one month and the maximum duration is one year.
    • Auto-renewals: After selecting this option, you can customize the number of renewals. If the number of renewals exceeds the value, auto-renewal will not take effect. If you do not configure the number of auto-renewals, the number of auto-renewals is not limited by default.
    Figure 1 Configuring auto-renewal
    If resources such as EIPs are bound to a node, you can select the resources to determine whether to enable auto-renewal with the node.
  5. Click OK.
Modifying Auto-Renewal
  3. Choose More > Change Auto-Renewal in the Operation column of a yearly/monthly node. You can also select multiple nodes at a time. To do so, choose More > Change Auto-Renewal in the function bar on the top of the page. In the displayed dialog box, confirm the nodes for which auto-renewal is to be modified.
  4. On the Modify Auto-Renew page, modify auto-renewal parameters.
    • Renewal Option: If auto-renewal is enabled for a node, Automatic is selected by default. To disable auto-renewal, select Manual.
    Figure 2 Modifying auto-renewal
  5. Click OK.
