Help Center/ Cloud Container Engine/ User Guide/ Networking/ Ingresses/ LoadBalancer Ingresses/ Routing and Forwarding Policies/ Configuring Multiple Forwarding Policies for a LoadBalancer Ingress
Updated on 2026-08-13 GMT+08:00
An ingress can route requests to multiple backend Services based on different matching policies. For example, requests can be routed to three different backend Services separately by accessing www.example.com/foo, www.example.com/bar, and foo.example.com/.
The URL registered in an ingress forwarding policy must be the same as the URL used to access the backend Service. Otherwise, a 404 error will be returned.
For example, the default access URL of the Nginx application is /usr/share/nginx/html. When adding /test to the ingress forwarding policy, ensure the access URL of your Nginx application contains /usr/share/nginx/html/test. Otherwise, error 404 will be returned.
Routing an Ingress to Multiple Services
You can route an ingress to multiple Services using either the CCE console or kubectl.
  2. Choose Services and Ingresses in the navigation pane, click the Ingresses tab, and click Create Ingress in the upper right corner.
  3. Configure ingress parameters.
    This example explains only key parameters for configuring forwarding policies. You can configure other parameters as required. For details, see Creating a LoadBalancer Ingress on the Console.
    Table 1 Key parameters
    Example
    Name
    Enter an ingress name.
    ingress-test
    Load Balancer
    Select a load balancer to be associated with the ingress or automatically create a load balancer.
    Shared
    Listener
    • Frontend Protocol: HTTP and HTTPS are available.
    • External Port: specifies the port of the load balancer listener.
    • External Port: 80
    Forwarding Policy
    • Domain Name: Enter an actual domain name to be accessed. If it is left blank, the ingress can be accessed through an IP address. The domain name must be registered and filed. Once a domain name is used by a forwarding policy, only that domain name will be accepted for access.
    • Path Matching Rule: Choose Prefix match, Exact match, or RegEx match.
    • Path: comes from a backend application for external access. It must work in the backend application. Otherwise, forwarding will not take effect.
    • Destination Service: Select an existing Service. Only Services that meet the requirements are automatically displayed in the Service list. If no Service meets the requirements, create one by following the operations provided in Services Supported by Ingresses.
    • Destination Service Port: Select the access port of the destination Service.
    Forwarding rule 1:
    • Domain Name: www.example.com
    • Path Matching Rule: Prefix match
    • Path: /foo
    • Destination Service: nginx
    • Destination Service Port: 80
    Forwarding rule 2:
    • Path: /bar
    Forwarding rule 3:
    • Domain Name: foo.example.com
    • Path: /
    Figure 1 Routing an ingress to multiple Services
  4. Click Create.
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    An example YAML file of an ingress associated with an existing load balancer is as follows:
    For clusters v1.23 or later:
    kind: Ingress
      annotations:
        kubernetes.io/elb.id: <your_elb_id>  # Replace it with the ID of your existing load balancer.
        kubernetes.io/elb.class: performance  # Load balancer type
        kubernetes.io/elb.port: '80'
      rules:
      - host: 'www.example.com'
        http:
          paths:
          - path: '/foo'
            backend:
              service:
                name: <your_service_name>  # Replace it with your target Service name.
                port:
                  number: 80             # Replace it with your target Service port.
            property:
          - path: '/bar'
            backend:
              service:
                port:
            property:
      - host: 'foo.example.com'
        http:
          paths:
          - path: '/'
            backend:
              service:
                port:
            property:
      ingressClassName: cce
    For clusters v1.21 or earlier:
    apiVersion: networking.k8s.io/v1beta1
    kind: Ingress
      annotations:
        kubernetes.io/ingress.class: cce
      rules:
        http:
          paths:
          - path: '/foo'
            backend:
              serviceName: <your_service_name>  # Replace it with your target Service name.
              servicePort: 80
            property:
          - path: '/bar'
            backend:
              serviceName: <your_service_name>  # Replace it with your target Service port.
              servicePort: 80
            property:
        http:
          paths:
          - path: '/'
            backend:
              servicePort: 80
            property:
  3. Create an ingress.
    If information similar to the following is displayed, the ingress has been created:
    ingress.networking.k8s.io/ingress-test created
  4. Check the created ingress.
    kubectl get ingress
    NAME           CLASS  HOSTS                               ADDRESS          PORTS   AGE
    ingress-test   cce    www.example.com,foo.example.com     121.**.**.**     80      10s
