Updated on 2026-09-21 GMT+08:00
Configuring HTTP/2 for a LoadBalancer Ingress
Ingresses can use HTTP/2 to expose Services. Connections from the load balancer to your application use HTTP/1.x by default. If your application is capable of receiving HTTP/2 requests, enable HTTP/2 by referring to Using the CCE Console or Using kubectl.
  • A CCE standard or Turbo cluster is available, and the cluster version meets the following requirements:
    • v1.23: v1.23.13-r0 or later
    • v1.25: v1.25.8-r0 or later
    • v1.27: v1.27.5-r0 or later
    • v1.28: v1.28.3-r0 or later
    • Other clusters of later versions
  • An available workload has been deployed in the cluster for external access. If no workload is available, deploy a workload by referring to Creating a Deployment, Creating a StatefulSet, or Creating a DaemonSet.
  • A Service for external access has been configured for the workload. Services Supported by LoadBalancer Ingresses lists the Service types supported by LoadBalancer ingresses.
  • You can obtain a trusted certificate from a certificate provider. For details, see Purchasing an SSL Certificate.
  • Only an HTTPS-compliant load balancer supports HTTP/2.
  • After HTTP/2 is configured, if you delete the advanced configuration for enabling HTTP/2 on the CCE console or delete the target annotation from the YAML file, HTTP/2 will be disabled on the ELB.
  • If multiple ingresses share the same external port on a load balancer, you are advised to use the same HTTP/2 configuration for these ingresses. Otherwise, the configuration of the first created ingress will take precedence. For details, see Configuring Multiple Ingresses to Use the Same Load Balancer.
Configuring HTTP/2 for an Ingress
You can configure HTTP/2 for an ingress using either the CCE console or kubectl.
  2. Choose Services and Ingresses in the navigation pane, click the Ingresses tab, and click Create Ingress in the upper right corner.
  3. Configure ingress parameters.
    This example explains only key parameters for configuring HTTP/2. You can configure other parameters as required. For details, see Creating a LoadBalancer Ingress on the Console.
    Table 1 Key parameters
    Example
    Name
    Enter an ingress name.
    ingress-test
    Load Balancer
    Select a load balancer to be associated with the ingress or automatically create a load balancer.
    Dedicated
    Listener
    • Frontend Protocol: Select HTTPS.
    • External Port: specifies the port of the load balancer listener. The default HTTPS port is 443.
    • Certificate Source: Select ELB server certificate or LTS secret.
    • Server Certificate:
      • If Certificate Source is set to ELB server certificate, use a certificate created on ELB. If no certificate is available, go to the ELB console and create one. For details, see Adding a Certificate.
      • If Certificate Source is set to LTS secret, kubernetes.io/tls and IngressTLS are supported. If no certificate is available, you can create a TLS certificate. For details about parameter settings, see Creating a Secret.
    • Advanced Options: Add advanced configurations, select HTTP2, and set its status to Enable.
    • Frontend Protocol: HTTPS
    • External Port: 443
    • Certificate Source: ELB server certificate
    • Server Certificate: cert-test
    • Advanced Options: HTTP2 enabled
    Forwarding Policy
    • Domain Name: Enter an actual domain name to be accessed. If it is left blank, the ingress can be accessed through an IP address. The domain name must be registered and filed. Once a domain name is used by a forwarding policy, only that domain name will be accepted for access.
    • Path Matching Rule: Choose Prefix match, Exact match, or RegEx match.
    • Path: comes from a backend application for external access. It must work in the backend application. Otherwise, forwarding will not take effect.
    • Destination Service: Select an existing Service. Only Services that meet the requirements are automatically displayed in the Service list. If no Service meets the requirements, create one by following the operations provided in Services Supported by Ingresses.
    • Destination Service Port: Select the access port of the destination Service.
    • Domain Name: You do not need to configure this parameter.
    • Path Matching Rule: Prefix match
    • Path: /
    • Destination Service: nginx
    • Destination Service Port: 80
    Figure 1 Configuring HTTP/2 for an ingress
  4. Click Create.
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    An example YAML file of an ingress associated with an existing load balancer is as follows:
    kind: Ingress
      annotations:
        kubernetes.io/elb.class: performance  # Load balancer type
        kubernetes.io/elb.id: <your_elb_id>  # Replace it with the ID of your existing load balancer.
        kubernetes.io/elb.ip: <your_elb_ip>  # Replace it with the IP address of your existing load balancer.
        kubernetes.io/elb.port: '443'
        kubernetes.io/elb.http2-enable: 'true' # Enable HTTP/2.
      tls:
      - secretName: ingress-test-secret    # Configure it as needed.
      rules:
      - host: ''
        http:
          paths:
          - path: '/'
            backend:
              service:
                name: <your_service_name>  # Replace it with your target Service name.
                port:
                  number: 80             # Replace it with your target Service port.
            property:
      ingressClassName: cce
    Table 2 HTTP/2 parameters
    Mandatory
    Type
    No
    String
    Whether HTTP/2 is enabled. Request forwarding using HTTP/2 improves access performance between your application and the load balancer. However, the load balancer still uses HTTP/1.x to forward requests to the backend server.
    Options:
    • true: enabled
    • false: disabled (default value)
    Note: HTTP/2 can be enabled or disabled only when the listener uses HTTPS. This parameter is invalid and defaults to false when the listener protocol is HTTP.
  3. Create an ingress.
    If information similar to the following is displayed, the ingress has been created:
    ingress.networking.k8s.io/ingress-test created
  4. Check the created ingress.
    kubectl get ingress
    NAME          CLASS    HOSTS     ADDRESS          PORTS   AGE
    ingress-test  cce      *         121.**.**.**     80,443  10s
