Configuring SNI for a LoadBalancer Ingress
An SNI certificate is an extended server certificate that allows the same IP address and port number to provide multiple access domain names for external systems. Different security certificates can be used based on the domain names requested by clients to ensure HTTPS communication security.
Configure SNI by setting both the default server certificate and the SNI certificate associated with the specific domain name. In the SSL handshake, the client provides the requested domain name. The load balancer then checks for the matching SNI certificate based on the domain name. It returns this certificate if available. Otherwise, it uses the default server certificate.
- Configuring SNI Using a TLS Certificate: First import a certificate into a secret. CCE automatically provisions the certificate on the ELB with a name prefixed by k8s_plb_default. CCE-managed certificates cannot be modified or deleted through the ELB console.
- Configuring SNI Using an ELB Certificate: You can use certificates created on the ELB console directly. This eliminates the need to manually configure cluster secrets, and you can update the certificates from the same console.
- An available workload has been deployed in the cluster for external access. If no workload is available, deploy a workload by referring to Creating a Deployment, Creating a StatefulSet, or Creating a DaemonSet.
- A Service for external access has been configured for the workload. Services Supported by LoadBalancer Ingresses lists the Service types supported by LoadBalancer ingresses.
- You have obtained a trusted server certificate and an SNI certificate from your certificate provider. For details, see Purchasing an SSL Certificate.
- When using a TLS certificate to configure SNI, create an IngressTLS or kubernetes.io/tls secret for the certificate. For details about how to create a secret, see Creating a Secret.
When using an ELB certificate to configure SNI, create a certificate on ELB. For details about how to create a certificate, see Adding a Certificate.
You can configure SNI through a TLS certificate using either the CCE console or kubectl.
- The SNI option is available only when HTTPS is used.
- Only one domain name can be specified for each SNI certificate. Wildcard-domain certificates are supported.
- Security policy (kubernetes.io/elb.tls-ciphers-policy) is supported only in clusters v1.17.11 or later.
- Choose Services and Ingresses in the navigation pane, click the Ingresses tab, and click Create Ingress in the upper right corner.
- Configure ingress parameters.
This example explains only key parameters for configuring SNI certificates. You can configure other parameters as needed. For details, see Creating a LoadBalancer Ingress on the Console.
Table 1 Key parameters Parameter
Example
Name
Enter an ingress name.
ingress-test
Load Balancer
Select a load balancer to be associated with the ingress or automatically create a load balancer.
Shared
Listener
- Frontend Protocol: Select HTTPS when configuring a certificate for an ingress.
- External Port: specifies the port of the load balancer listener. The default HTTPS port is 443.
- Certificate Source: Select TLS secret.
- Server Certificate: kubernetes.io/tls and IngressTLS are supported.
If no certificate is available, you can create a TLS certificate. For details about parameter settings, see Creating a Secret.
- SNI: Enter a domain name and select a certificate. The SNI certificate must contain the domain name information. SNI certificates support two TLS secret types: kubernetes.io/tls and IngressTLS.
- Frontend Protocol: HTTPS
- External Port: 443
- Certificate Source: TLS secret
- Server Certificate: test
- SNI:
- Domain Name: example.com
- Certificate: example-test
Forwarding Policy
- Domain Name: Enter an actual domain name to be accessed. If it is left blank, the ingress can be accessed through an IP address. The domain name must be registered and filed. Once a domain name is used by a forwarding policy, only that domain name will be accepted for access.
- Path Matching Rule: Choose Prefix match, Exact match, or RegEx match.
- Path: comes from a backend application for external access. It must work in the backend application. Otherwise, forwarding will not take effect.
- Destination Service: Select an existing Service. Only Services that meet the requirements are automatically displayed in the Service list. If no Service meets the requirements, create one by following the operations provided in Services Supported by Ingresses.
- Destination Service Port: Select the access port of the destination Service.
- Path Matching Rule: Prefix match
- Path: /
- Destination Service: nginx
- Destination Service Port: 80
Figure 1 Configuring SNI using a TLS certificate
- Click OK.
In this example, the sni-test-secret SNI certificate is used as an example. The specified domain name must be the same as that of the SNI certificate.
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Create a YAML file named ingress-test.yaml. You can change the file name if you want to.
vi ingress-test.yaml
An example YAML file of an ingress associated with an automatically created load balancer is as follows:
For clusters v1.23 or later:apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test annotations: kubernetes.io/elb.class: performance kubernetes.io/elb.port: '443' kubernetes.io/elb.autocreate: '{ "type": "public", "bandwidth_name": "cce-bandwidth-******", "bandwidth_chargemode": "bandwidth", "bandwidth_size": 5, "bandwidth_sharetype": "PER", "eip_type": "5_bgp", # EIP "available_zone": [ "ap-southeast-1a" ], # The AZ where the load balancer is located "elb_virsubnet_ids":["b4bf8152-6c36-4c3b-9f74-2229f8e640c9"], # Subnet network ID "l7_flavor_name": "L7_flavor.elb.s1.small" # Layer 7 load balancer flavor name }' kubernetes.io/elb.tls-ciphers-policy: tls-1-2 spec: tls: - secretName: ingress-test-secret # Server certificate name - hosts: - example.com # Domain name specified when an SNI certificate is issued secretName: sni-test-secret # SNI certificate rules: - host: example.com # The domain name must be the same as the value of hosts in the tls field. http: paths: - path: '/' backend: service: name: <your_service_name> # Replace it with your target Service name. port: number: 80 # Replace it with your target Service port. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: cceFor clusters v1.21 or earlier:apiVersion: networking.k8s.io/v1beta1 kind: Ingress metadata: name: ingress-test annotations: kubernetes.io/elb.class: performance kubernetes.io/ingress.class: cce kubernetes.io/elb.port: '443' kubernetes.io/elb.autocreate: '{ "type": "public", "bandwidth_name": "cce-bandwidth-******", "bandwidth_chargemode": "bandwidth", "bandwidth_size": 5, "bandwidth_sharetype": "PER", "eip_type": "5_bgp", # EIP "available_zone": [ "ap-southeast-1a" ], # The AZ where the load balancer is located "elb_virsubnet_ids":["b4bf8152-6c36-4c3b-9f74-2229f8e640c9"], # Subnet network ID "l7_flavor_name": "L7_flavor.elb.s1.small" # Layer 7 load balancer flavor name }' kubernetes.io/elb.tls-ciphers-policy: tls-1-2 spec: tls: - secretName: ingress-test-secret # Server certificate name - hosts: - example.com # Domain name specified when an SNI certificate is issued secretName: sni-test-secret # SNI certificate rules: - host: example.com # The domain name must be the same as the value of hosts in the tls field. http: paths: - path: '/' backend: serviceName: <your_service_name> # Replace it with your target Service name. servicePort: 80 # Replace it with your target Service port. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH - Create an ingress.
If information similar to the following is displayed, the ingress has been created:
ingress.networking.k8s.io/ingress-test created
- Check the created ingress.
kubectl get ingress
NAME CLASS HOSTS ADDRESS PORTS AGE ingress-test cce example.com 121.**.**.** 80,443 10s
- Use HTTPS to access the ingress. ${ELB_IP} specifies the IP address accessed by the target ingress.
curl -H "Host:example.com" -k https://${ELB_IP}:443If the ingress can be accessed, the certificate is configured.
You can configure SNI using an ELB certificate for an ingress through either the CCE console or kubectl.
- If both an ELB certificate and a TLS certificate are specified for the same ingress, the ingress will use the ELB certificate.
- CCE does not check whether an ELB certificate is valid. It only checks whether the certificate is present.
- Only ingresses in clusters v1.19.16-r2, v1.21.5-r0, v1.23.3-r0, or later support ELB certificates.
Table 2 Key parameters Parameter
Example
Name
ingress-test
Load Balancer
Shared
Listener
- Frontend Protocol: Select HTTPS.
- Certificate Source: Select ELB server certificate.
- Server Certificate: Use a certificate created on ELB.
If no certificate is available, go to the ELB console and create one. For details, see Adding a Certificate.
- SNI: Select the corresponding SNI certificate, which must contain the domain name information.
- Certificate Source: ELB server certificate
- Server Certificate: cert-test
- SNI: cert-example
Forwarding Policy
- Domain Name: You do not need to configure this parameter.
- Path: /
Figure 2 Configuring SNI using an ELB certificate
- Click OK.
To use an ELB certificate for an ingress, you can specify the kubernetes.io/elb.tls-certificate-ids annotation.
An example YAML file of an ingress associated with an existing load balancer is as follows:
For clusters v1.23 or later:apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test namespace: default annotations: kubernetes.io/elb.port: '443' kubernetes.io/elb.id: 0b9a6c4d-bd8b-45cc-bfc8-ff0f9da54e95 kubernetes.io/elb.class: union kubernetes.io/elb.tls-certificate-ids: 058cc023690d48a3867ad69dbe9cd6e5,b98382b1f01c473286653afd1ed9ab63 spec: rules: - host: '' http: paths: - path: '/' backend: service: name: <your_service_name> # Replace it with your target Service name. port: number: 80 # Replace it with your target Service port. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: cceFor clusters v1.21 or earlier:
apiVersion: networking.k8s.io/v1beta1 kind: Ingress metadata: name: ingress-test annotations: kubernetes.io/ingress.class: cce kubernetes.io/elb.port: '443' kubernetes.io/elb.id: 0b9a6c4d-bd8b-45cc-bfc8-ff0f9da54e95 kubernetes.io/elb.class: union kubernetes.io/elb.tls-certificate-ids: 058cc023690d48a3867ad69dbe9cd6e5,b98382b1f01c473286653afd1ed9ab63 spec: rules: - host: '' http: paths: - path: '/' backend: serviceName: <your_service_name> # Replace it with your target Service name. servicePort: 80 property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITHTable 3 Key parameters Parameter
Type
String
ELB certificate IDs, which are separated by comma (,). The list length is greater than or equal to 1. The first ID in the list is the server certificate, and the other IDs are SNI certificates in which a domain name must be contained.
If an SNI certificate cannot be found based on the domain name requested by the client, the server certificate will be returned by default.
To obtain the certificate, log in to the CCE console, choose Service List > Networking > Elastic Load Balance, and choose Certificates in the navigation pane. In the certificate list, copy the ID under the target certificate name.
kubectl get ingress
NAME CLASS HOSTS ADDRESS PORTS AGE ingress-test cce * 121.**.**.** 80,443 10s
SNI Certificate Effectiveness When Multiple Ingresses Share the Same Port
In a cluster, multiple ingresses can use the same listener (the same port on a single load balancer). The SNI certificates configured for each ingress are automatically aggregated and applied concurrently.
For example, the table below shows the configuration of two ingresses. ingress1 is the first route. (For details about the first route, see How Can I Determine Which Ingress the Listener Settings Have Been Applied To?)
| Ingress Name | ingress1 | ingress2 |
| kubernetes.io/elb.tls-certificate-ids | cert-id-A,cert-id-B | cert-id-C,cert-id-D |
The first ID in kubernetes.io/elb.tls-certificate-ids is the server certificate, and the remaining IDs are SNI certificates.
When multiple ingresses use the same listener:
- Only the server certificate cert-id-A configured in the first ingress (ingress1) is used. Server certificates configured in other ingresses (such as cert-id-C in ingress2) are ignored.
- SNI certificates are automatically aggregated across all ingresses, so cert-id-B and cert-id-D both apply.
