Migrating a Node
        Migration Scenario  |
        Migration  |
        Operation  |
        Source Node Pool  |
        Target Node Pool  |
        Custom node pool  |
        Default node pool (DefaultPool)  |
        Supported  |
        Migrating Nodes from a Custom Node Pool to the Default Node Pool  |
        Custom node pool  |
        Supported by clusters of v1.23 or later  |
        Migrating Nodes from the Default Node Pool to a Custom Node Pool  |
        Custom node pool  |
        Custom node pool  |
        Not supported  |
        None  |
 - In the navigation pane, choose Nodes and click the Node Pools tab.
 - Click View Node in the Operation column of the node pool to be migrated.
 - Choose More > Migrate Node in the Operation column of the target node to migrate the node.
 - In the displayed Migrate Node dialog box, confirm the information.
     - The migration does not affect custom resource tags, and Kubernetes labels and taints of the node.
 - After the migration, system labels cce.cloud.com and cce-nodepool on the node will be deleted. If an existing workload uses these labels for affinity or anti-affinity scheduling, the existing pods on the node will be stopped and rescheduled when kubelet is restarted.
 - Locate the target node pool and choose More > Accept Node.
 - In the Accept Node dialog box, select the nodes that meet the following conditions:
- The nodes and the current node pool are deployed in the same VPC and subnet.
 - The nodes and the current node pool belong to the same enterprise project.
 - The nodes and the current node pool are in the same cloud server group.
 - The billing mode of the nodes is supported by the current node pool.
 - The nodes are running and they are from the default node pool.
 - The flavor, AZ, resource reservation, container engine, and OS configurations of the nodes are the same as those of the node pool.
 - Click OK.
     - After nodes are migrated into a node pool, the pool's resource tags, Kubernetes labels, and Kubernetes taints will be synchronized to the nodes. If there is a conflict, the node pool's configurations will take precedence.
 - After the migration, the pool's security group will take over the nodes' original security group.
 - After the migration, the pool's agency will take over the nodes' original agency.
 - After the migration, the nodes' original login mode will remain unchanged.
 - After a node is migrated to a node pool after being accepted by the cluster, its acceptance tag will be removed. Scaling in the node pool may result in the removal of the node.
