Help Center/
      Cloud Container Engine/
        User Guide (ME-Abu Dhabi Region)/
        Node Pools/
        Managing a Node Pool/
      Synchronizing Node Pools
After the configuration of a node pool is updated, some configurations cannot be automatically synchronized for existing nodes. You can manually synchronize configurations for these nodes.
  - Do not delete or reset nodes during batch synchronization. Otherwise, the synchronization of node pool configuration may fail.
 - This operation involves resetting nodes. Workloads running on a node may be interrupted due to standalone deployment or insufficient schedulable resources. Evaluate the upgrade risks and perform the upgrade during off-peak hours. Alternatively, specify a disruption budget for your key applications to ensure the availability of these applications during the upgrade.
 - During configuration synchronization for existing nodes, the nodes will be reset, and the system disks and data disks will be cleared. Back up important data before the synchronization.
 - Only some node pool parameters can be synchronized by resetting nodes. The constraints are as follows:
- Changes to the container engine, OS, or pre-/post-installation script in a node pool take effect only on new nodes. To synchronize the modification onto existing nodes, manually reset these nodes.
 - Changes to resource tags and Kubernetes labels/taints in a node pool will be automatically synchronized to existing nodes after the options of Synchronization for Existing Nodes are selected. You do not need to reset these nodes.
Synchronizing a Single Node
- Log in to the CCE console.
 - Click the cluster name to access the cluster console. Choose Nodes in the navigation pane. In the right pane, click the Nodes tab.
 - Find Node pool updated in the Node Name column of the existing nodes in the node pool.
 - Move the cursor to Node pool updated. The Reset button is displayed. You can then determine whether to reset the node immediately.
   Parent topic: Managing a Node Pool
