Copying a Node Pool
You can copy the configuration of an existing node pool on the CCE console to create new node pools.
  1. Log in to the CCE console.
  2. Click the cluster name to access the cluster console. Choose Nodes in the navigation pane. In the right pane, click the Node Pools tab.
  3. Choose More > Copy in the Operation column of the target node pool.
  4. In the Copy Resource Pool window, the configurations of the node pool to be copied are displayed. Modify the configurations as needed. For details, see Creating a Node Pool. After confirming the configuration, click Next: Confirm.
  5. On the Confirm page, confirm the node pool configurations and click Submit. Then, a new node pool is created based on the modified configurations.
