Updated on 2026-09-21 GMT+08:00
GPU View
GPU resource metrics are used to measure GPU performance and usage, including the GPU usage, temperature, and GPU memory, so you can better monitor the GPU.
Metric Description
Figure 1 GPU view
Table 1 GPU metrics
Metric
Unit
Cluster - GPU Memory Usage
GPU memory usage of the cluster.
Formula: GPU memory used by containers in the cluster/Total GPU memory of the cluster
Cluster - GPU Compute Usage
GPU compute usage of the cluster.
Formula: GPU compute used by containers in the cluster/Total GPU compute of the cluster
Node - Used GPU Memory
Bytes
GPU memory used by each node.
Node - GPU Compute Usage
GPU compute usage of each node.
Formula: Total GPU compute used by containers on the node/Total GPU compute of the node
Node - GPU Memory Usage
GPU memory usage of each node.
Formula: Total GPU memory used by containers on the node/Total GPU memory of the node
GPU - Used GPU Memory
Bytes
Total GPU memory used by containers on the GPU
GPU - GPU Compute Usage
Compute usage of each GPU
Formula: Total compute used by containers on the GPU/Total GPU compute of the GPU
GPU - Temperature
°C
Temperature of each GPU.
GPU - Memory Clock
Hz
Memory clock of each GPU.
GPU - PCIe Bandwidth
Bytes/s
PCIe bandwidth of each GPU.
Metric List
The following is the metric list of the GPU view.
Table 2 Metric description
Metric
Type
cce_gpu_gpu_utilization
Gauge
GPU compute usage.
cce_gpu_memory_utilization
Gauge
GPU memory usage.
cce_gpu_memory_used
Gauge
Used GPU memory.
cce_gpu_memory_total
Gauge
Total GPU memory.
cce_gpu_memory_free
Gauge
Free GPU memory.
cce_gpu_memory_clock
Gauge
The speed at which the GPU memory operates.
cce_gpu_gpu_temperature
Gauge
GPU temperature.
cce_gpu_pcie_link_bandwidth
Gauge
GPU PCIe bandwidth.
cce_gpu_pcie_throughput_rx
Gauge
GPU PCIe RX bandwidth.
