Node Pool View
The node pool view displays the usage and allocation of node pool resources, so you can better monitor the load of a node pool.
Metric Description
You can view the node pool metrics in the following table.
| Metric | Unit | Description |
| Node Pool CPU Request Rate | % | Total CPU request of pods on all nodes in the node pool/Total CPU of all nodes in the node pool |
| Node Pool CPU Usage | % | Total CPU used by all nodes in the node pool/Total CPU of the node pool |
| Node Pool Memory Request Rate | % | Total memory request of pods on all nodes in the node pool/Total memory of all nodes in the node pool |
| Node Pool Memory Usage | % | Total memory used by all nodes in the node pool/Total memory of the node pool |
| Node Count Trend | N/A | The number of nodes in the node pool. |
Metric List
The following is the metric list of the node pool view.
| kube_node_labels | Gauge | Node label. label_cce_cloud_com_cce_nodepool is the name of the CCE node pool. If the label does not exist, the default pool will be used. |
| node_cpu_seconds_total | Counter | Seconds the CPUs spent in each mode. |
| node_memory_MemAvailable_bytes | Gauge | Available memory of a node. |
| node_memory_MemTotal_bytes | Gauge | Total memory of a node. |
| kube_pod_container_resource_requests | Gauge | Resource requests of a container. |
