Node View
The node view displays node resource, network, and disk metrics, so you can better monitor a node.
Metric Description
You can view the node metrics in the following tables.
| Metric | Unit | Description |
| Node CPU Rate | % | CPU usage of the node. |
| CPU Requests Commitment | % | CPU requests of the node/Total CPU of the node |
| CPU Limits Commitment | % | CPU limits/Total CPU of the node |
| Memory Usage | % | Memory usage of the node. |
| Memory Requests Commitment | % | Memory requests of the node/Total memory of the node |
| Memory Limits Commitment | % | Memory limits of the node/Total memory of the node |
| Pods CPU Rate | % | CPU usage of each pod on the node |
| Memory Usage | Bytes | Memory usage of the pod on the node |
| Receive Bandwidth | Bytes/s | The number of bytes received by the node per second. |
| Transmit Bandwidth | Bytes/s | The number of bytes sent by the node per second. |
| Network Receive Rate (Pod) | Bytes/s | The number of bytes received by each pod on the node per second. |
| Network Transmit Rate (Pod) | Bytes/s | The number of bytes sent by the pod on the node per second. |
| Rate of Received Packets | Count/s | The number of packets received by each pod on the node per second. |
| Rate of Transmitted Packets | Count/s | The number of packets transmitted by each pod on the node per second. |
| Rate of Received Packets Dropped | Count/s | The number of packets not received by each pod on the node per second. |
| Rate of Transmitted Packets Dropped | Count/s | The number of packets transmitted by each pod on the node but not received by the receiver per second. |
| Node I/O Per Second (Reads + Writes) | Count/s | Total number of read and write operations performed by each pod on the disk per second. |
| Node I/O Throughput (Read + Write) | Bytes/s | Total number of bytes read from and written to the disk by each pod on the node per second. |
Metric List
The following is the metric list of the node view.
| Metric | Type | Description |
| kube_pod_container_resource_limits | Gauge | Container resource limits |
| kube_pod_status_phase | Gauge | The current phase of a pod. |
| kube_node_status_allocatable | Gauge | Allocatable resources on a node. |
| kube_pod_container_resource_requests | Gauge | Container resource requests. |
| node_memory_MemAvailable_bytes | Gauge | Available memory on a node, in bytes. |
| node_memory_MemTotal_bytes | Gauge | Total memory on a node, in bytes. |
| node_cpu_seconds_total | Counter | Cumulative CPU time of a node in each mode, in seconds. |
| container_cpu_usage_seconds_total | Counter | Cumulative CPU time consumed by a container, in seconds. |
| container_memory_rss | Gauge | Resident set size (RSS), which is the amount of physical memory held by a process. |
| container_network_receive_bytes_total | Counter | Cumulative count of bytes received over the container network. |
| container_network_transmit_bytes_total | Counter | Cumulative count of bytes transmitted over the container network. |
| container_network_receive_packets_total | Counter | Cumulative count of packets received over the container network. |
| container_network_transmit_packets_total | Counter | Cumulative count of packets transmitted over the container network. |
| container_network_transmit_packets_dropped_total | Counter | Cumulative count of packets dropped while transmitting over the container network. |
| container_fs_reads_total | Counter | Cumulative count of reads completed by a container. |
| container_fs_writes_total | Counter | Cumulative count of writes completed by a container. |
| container_fs_reads_bytes_total | Counter | Cumulative count of bytes read by a container. |
| container_fs_writes_bytes_total | Counter | Cumulative count of bytes written by a container. |
