Key Node Commands
Check Items
Whether some key commands that the node upgrade depends on are working
- Scenario 1: Executing the RPM package manager command failed.
Executing rpm failed. In this case, log in to the affected node and check whether the following command is available:
rpm -qa
If the command cannot be used, run the following command:rpm --rebuilddb
If the fault persists, reset the node. For details, see Resetting a Node.
- Scenario 2: Executing the dpkg package manager command failed.
Executing dpkg failed. In this case, log in to the affected node and check whether the following command is available:
dpkg -l
If the command cannot be used, reset the node. For details, see Resetting a Node.
- Scenario 2: Executing systemctl status failed.
If systemctl status cannot be used on a node, many check items will fail. In this case, log in to the affected node and check whether the following command is available:
systemctl status kubelet
If systemctl cannot be used, reset the node. For details, see Resetting a Node.
