Configuring the Priorities of Forwarding Rules for LoadBalancer Ingresses
When ingresses use the same load balancer listener, forwarding rules can be prioritized based on the following rules:
  • Forwarding rules of different ingresses: The rules are sorted based on the priorities (ranging from 1 to 1000) of the kubernetes.io/elb.ingress-order annotation. A smaller value indicates a higher priority.
  • Forwarding rules of an ingress: If the kubernetes.io/elb.rule-priority-enabled annotation is set to true, the forwarding rules are sorted based on the sequence in which they are added during ingress creation. A forwarding rule added earlier indicates a higher priority. If the kubernetes.io/elb.rule-priority-enabled annotation is not configured, the default sorting of the forwarding rules on the load balancer will be used.
If the preceding annotations are not configured, the default sorting of the forwarding rules on the load balancer will be used, regardless of whether the forwarding rules are of the same ingress or different ingresses under the same load balancer listener.
  • A CCE standard cluster is available, and the cluster version meets the following requirements:
    • v1.23: v1.23.15-r0 or later
    • v1.25: v1.25.10-r0-r0 or later
    • v1.27: v1.27.7-r0 or later
    • v1.28: v1.28.5-r0 or later
    • v1.29: v1.29.1-r10 or later
    • Other clusters of later versions
  • An available workload has been deployed in the cluster for external access. If no workload is available, deploy a workload by referring to Creating a Deployment, Creating a StatefulSet, or Creating a DaemonSet.
  • A Service for external access has been configured for the workload. Services Supported by LoadBalancer Ingresses lists the Service types supported by LoadBalancer ingresses.
Notes and Constraints
Ingresses support prioritizing forwarding rules only when dedicated load balancers are used.
Using kubectl
  1. Use kubectl to access the cluster. For details, see Connecting to a Cluster Using kubectl.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    The following shows an example configuration using an existing load balancer:
    kind: Ingress
      namespace: default
      annotations:
        kubernetes.io/elb.port: '88'
        kubernetes.io/elb.id: 2c623150-17bf-45f1-ae6f-384b036f547e    # ID of an existing load balancer
        kubernetes.io/elb.class: performance    # Load balancer type
        kubernetes.io/elb.ingress-order: '1'    # Priority of a forwarding rule of different ingresses
        kubernetes.io/elb.rule-priority-enabled: 'true'   # The forwarding rules of an ingress are sorted based on the forwarding rule sequence in paths.
      rules:
        - host: ''
          http:
            paths:
              - path: /test1
                backend:
                  service:
                    port:
                      number: 8081
                property:
              - path: /test2
                backend:
                  service:
                    port:
                      number: 8081
                property:
      ingressClassName: cce
    Table 1 Annotations for configuring the priorities of forwarding rules
    Type
    String
    Specifies the sequence of forwarding rules of different ingresses. The value ranges from 1 to 1000. A smaller value indicates a higher priority. The priority of a forwarding rule must be unique under the same load balancer listener.
    This parameter is available only for dedicated load balancers.
    When this annotation is configured, the kubernetes.io/elb.rule-priority-enabled annotation is enabled by default. The forwarding rules of each ingress will be sorted.
    String
    This parameter can only be set to true, indicating to sort the forwarding rules of an ingress. The priorities of the forwarding rules are determined based on the sequence in which they are added during ingress creation. A forwarding rule added earlier indicates a higher priority.
    If this parameter is not configured, the default sorting of the forwarding rules on the load balancer will be used. After this parameter is enabled, it cannot be disabled.
  3. Create an ingress.
    If information similar to the following is displayed, the ingress has been created:
    ingress/ingress-test created
  4. Check the created ingress.
    kubectl get ingress
    NAME          CLASS    HOSTS     ADDRESS          PORTS   AGE
    ingress-test  cce      *         121.**.**.**     88      10s
