Situation Awareness
Using an EVS Disk Through a Dynamic PV
Updated on 2024-01-26 GMT+08:00
CCE allows you to specify a StorageClass to automatically create an EVS disk and the corresponding PV. This function is applicable when no underlying storage volume is available.
  • You have created a cluster and installed the CSI add-on (everest) in the cluster.
  • If you want to create a cluster using commands, use kubectl to connect to the cluster. For details, see Connecting to a Cluster Using kubectl.
  • EVS disks cannot be attached across AZs and cannot be used by multiple workloads, multiple pods of the same workload, or multiple tasks. Data sharing of a shared disk is not supported between nodes in a CCE cluster. If an EVS disk is attacked to multiple nodes, I/O conflicts and data cache conflicts may occur. Therefore, create only one pod when creating a Deployment that uses EVS disks.
  • For clusters earlier than v1.19.10, if an HPA policy is used to scale out a workload with EVS disks attached, the existing pods cannot be read or written when a new pod is scheduled to another node.
    For clusters of v1.19.10 and later, if an HPA policy is used to scale out a workload with EVS disks attached, a new pod cannot be started because EVS disks cannot be attached.
(Console) Automatically Creating an EVS Disk
  2. Dynamically create a PVC and PV.
    1. Choose Storage from the navigation pane, and click the PersistentVolumeClaims (PVCs) tab. Click Create PVC in the upper right corner. In the dialog box displayed, configure the PVC parameters.
      PVC Type
      In this example, select EVS.
      PVC Name
      Enter the PVC name, which must be unique in the same namespace.
      Creation Method
      • If no underlying storage is available, select Dynamically provision to create a PVC, PV, and underlying storage on the console in cascading mode.
      • If underlying storage is available, create a storage volume or use an existing storage volume to statically create a PVC based on whether a PV has been created. For details, see Using an Existing EVS Disk Through a Static PV.
      In this example, select Dynamically provision.
      Storage Classes
      The storage class for EVS disks is csi-disk.
      AZ
      Select the AZ of the EVS disk. The AZ must be the same as that of the cluster node.
      An EVS disk can only be mounted to a node in the same AZ. After an EVS disk is created, its AZ cannot be changed.
      Disk Type
      Select an EVS disk type.
      Access Mode
      EVS disks support only ReadWriteOnce, indicating that a storage volume can be mounted to one node in read/write mode. For details, see Volume Access Modes.
      Capacity (GiB)
      Capacity of the requested storage volume.
      Encryption
      You can select Encryption and an encryption key to encrypt underlying storage. Before using the encryption function, check whether the region where the EVS disk is located supports disk encryption.
      Enterprise Project
      Supported enterprise projects: default, the one to which the cluster belongs, or the one specified by the storage class.
    2. Click Create.
      You can choose Storage in the navigation pane and view the created PVC and PV on the PersistentVolumeClaims (PVCs) and PersistentVolumes (PVs) tab pages.
  3. Create an application.
    1. In the navigation pane on the left, click Workloads. In the right pane, click the StatefulSets tab.
    2. Click Create Workload in the upper right corner. On the displayed page, click Data Storage in the Container Settings area and click Add Volume to select PVC.
      Mount and use storage volumes, as shown in Table 1. For details about other parameters, see Workloads.
      Table 1 Mounting a storage volume
      PVC
      Select an existing EVS volume.
      An EVS volume cannot be repeatedly mounted to multiple workloads.
      Mount Path
      Enter a mount path, for example, /tmp.
      This parameter indicates the container path to which a data volume will be mounted. Do not mount the volume to a system directory such as / or /var/run; this action may cause container errors. You are advised to mount the volume to an empty directory. If the directory is not empty, ensure that there are no files that affect container startup. Otherwise, the files will be replaced, causing container startup failures or workload creation failures.
      NOTICE:
      If a volume is mounted to a high-risk directory, use an account with minimum permissions to start the container. Otherwise, high-risk files on the host machine may be damaged.
      Subpath
      Enter a subpath, for example, tmp, indicating that data in the mount path of the container will be stored in the tmp folder of the volume.
      A subpath is used to mount a local volume so that the same data volume is used in a single pod. If this parameter is left blank, the root path is used by default.
      Permission
      • Read-only: You can only read the data in the mounted volumes.
      • Read/Write: You can modify the data volumes mounted to the path. Newly written data is not migrated if the container is migrated, which may cause data loss.
      In this example, the disk is mounted to the /data path of the container. The container data generated in this path is stored in the EVS disk.
      A non-shared EVS disk cannot be attached to multiple pods in a workload. Otherwise, the pods cannot start properly. Ensure that the number of workload pods is 1 when you attach an EVS disk.
    3. After the configuration, click Create Workload.
      After the workload is created, the data in the container mount directory will be persistently stored. Verify the storage by referring to Verifying Data Persistence.
(kubectl) Automatically Creating an EVS Disk
  1. Use kubectl to connect to the cluster.
  2. Use StorageClass to dynamically create a PVC and PV.
    1. Create the pvc-evs-auto.yaml file.
      apiVersion: v1
      kind: PersistentVolumeClaim
        namespace: default
        annotations:
            everest.io/disk-volume-type: SAS    # EVS disk type.
          everest.io/crypt-key-id: <your_key_id>    # (Optional) Encryption key ID. Mandatory for an encrypted disk.
          everest.io/enterprise-project-id: <your_project_id>  # (Optional) Enterprise project ID. If an enterprise project is specified, use the same enterprise project when creating a PVC. Otherwise, the PVC cannot be bound to a PV.
        labels:
          failure-domain.beta.kubernetes.io/region: <your_region>   # Region of the node where the application is to be deployed.
          failure-domain.beta.kubernetes.io/zone: <your_zone>       # AZ of the node where the application is to be deployed.
        accessModes:
        - ReadWriteOnce               # The value must be ReadWriteOnce for EVS disks.
        resources:
          requests:
            storage: 10Gi             # EVS disk capacity, ranging from 1 to 32768.
        storageClassName: csi-disk    # Storage class type for EVS disks.
      Table 2 Key parameters
      Mandatory
      Yes
      Region where the cluster is located.
      For details about the value of region, see Regions and Endpoints.
      Yes
      AZ where the EVS volume is created. It must be the same as the AZ planned for the workload.
      For details about the value of zone, see Regions and Endpoints.
      Yes
      EVS disk type. All letters are in uppercase.
      • SATA: common I/O
      • SAS: high I/O
      • SSD: ultra-high I/O
      No
      This parameter is mandatory when an EVS disk is encrypted. Enter the encryption key ID selected during EVS disk creation. You can use a custom key or the default key named evs/default.
      To obtain a key ID, log in to the DEW console, locate the key to be encrypted, and copy the key ID.
      No
      Optional.
      Enterprise project ID of the EVS disk. If an enterprise project is specified, specify the same enterprise project when creating a PVC. Otherwise, the PVC cannot be bound to a PV.
      To obtain the enterprise project ID, log in to the Cloud Server Console. In the navigation pane, choose Elastic Volume Service > Disks. Click the name of the target EVS disk to go to its details page. On the Summary tab page, click the enterprise project in Management Information to access the enterprise project console. Copy the corresponding ID to obtain the ID of the enterprise project to which the EVS disk belongs.
      storage
      Yes
      Requested PVC capacity, in Gi. The value ranges from 1 to 32768.
      storageClassName
      Yes
      The storage class name of the EVS volumes is csi-disk.
    2. Run the following command to create a PVC:
      kubectl apply -f pvc-evs-auto.yaml
    1. Create a file named web-evs-auto.yaml. In this example, the EVS volume is mounted to the /data path.
      apiVersion: apps/v1
      kind: StatefulSet
        namespace: default
        replicas: 1
        selector:
          matchLabels:
            app: web-evs-auto
        serviceName: web-evs-auto   # Headless Service name.
        template:
            labels:
              app: web-evs-auto
            containers:
            - name: container-1
              image: nginx:latest
              volumeMounts:
              - name: pvc-disk    # Volume name, which must be the same as the volume name in the volumes field.
                mountPath: /data  # Location where the storage volume is mounted.
            imagePullSecrets:
              - name: default-secret
            volumes:
              - name: pvc-disk    # Volume name, which can be customized.
                persistentVolumeClaim:
                  claimName: pvc-evs-auto    # Name of the created PVC.
      apiVersion: v1
      kind: Service
        name: web-evs-auto   # Headless Service name.
        namespace: default
        labels:
          app: web-evs-auto
        selector:
          app: web-evs-auto
        clusterIP: None
        ports:
          - name: web-evs-auto
            targetPort: 80
            nodePort: 0
            port: 80
            protocol: TCP
        type: ClusterIP
    2. Run the following command to create a workload to which the EVS volume is mounted:
      kubectl apply -f web-evs-auto.yaml
  1. View the deployed application and EVS volume files.
    1. Run the following command to view the created pod:
      kubectl get pod | grep web-evs-auto
      Expected output:
      web-evs-auto-0                  1/1     Running   0               38s
    2. Run the following command to check whether the EVS volume has been mounted to the /data path:
      kubectl exec web-evs-auto-0 -- df | grep data
      Expected output:
      /dev/sdc              10255636     36888  10202364   0% /data
    3. Run the following command to view the files in the /data path:
      kubectl exec web-evs-auto-0 -- ls /data
      Expected output:
      lost+found
  2. Run the following command to create a file named static in the /data path:
    kubectl exec web-evs-auto-0 --  touch /data/static
    Expected output:
    lost+found
    static
  4. Run the following command to delete the pod named web-evs-auto-0:
    kubectl delete pod web-evs-auto-0
    Expected output:
    pod "web-evs-auto-0" deleted
  5. After the deletion, the StatefulSet controller automatically creates a replica with the same name. Run the following command to check whether the files in the /data path have been modified:
    Expected output:
    lost+found
    static
    If the static file still exists, the data in the EVS volume can be stored persistently.
Related Operations
You can also perform the operations listed in Table 3.
Table 3 Related operations
Operation
Expanding the capacity of an EVS disk
Quickly expand the capacity of a mounted EVS disk on the CCE console.
  1. Choose Storage from the navigation pane, and click the PersistentVolumeClaims (PVCs) tab. Click More in the Operation column of the target PVC and select Scale-out.
  2. Enter the capacity to be added and click OK.
Viewing events
You can view event names, event types, number of occurrences, Kubernetes events, first occurrence time, and last occurrence time of the PVC or PV.
  1. Choose Storage from the navigation pane, and click the PersistentVolumeClaims (PVCs) or PersistentVolumes (PVs) tab.
  2. Click View Events in the Operation column of the target PVC or PV to view events generated within one hour (event data is retained for one hour).
Viewing a YAML file
You can view, copy, and download the YAML files of a PVC or PV.
  2. Click View YAML in the Operation column of the target PVC or PV to view or download the YAML.
