Situation Awareness
CCE Container Storage (Everest)
Updated on 2024-01-26 GMT+08:00
Introduction
everest is a cloud native container storage system, which enables clusters of Kubernetes v1.15.6 or later to access cloud storage services through the Container Storage Interface.
everest is a system resource add-on. It is installed by default when a cluster of Kubernetes v1.15 or later is created.
  • If your cluster is upgraded from v1.13 to v1.15, storage-driver is replaced by everest (v1.1.6 or later) for container storage. The takeover does not affect the original storage functions.
  • In version 1.2.0 of the everest add-on, key authentication is optimized when OBS is used. After the everest add-on is upgraded from a version earlier than 1.2.0, restart all workloads that use OBS in the cluster. Otherwise, workloads may not be able to use OBS.
  • By default, this add-on is installed in clusters of v1.15 and later. For clusters of v1.13 and earlier, the storage-driver add-on is installed by default.
Installing the Add-on
This add-on has been installed by default. If it is uninstalled due to some reasons, you can reinstall it by performing the following steps:
  1. Log in to the CCE console and click the cluster name to access the cluster console. Choose Add-ons in the navigation pane, locate CCE Container Storage (Everest) on the right, and click Install.
  2. On the Install Add-on page, configure the specifications.
    Table 1 Add-on configuration
    Pods
    Number of pods for the add-on.
    High availability is not possible with a single pod. If an error occurs on the node where the add-on instance runs, the add-on will fail.
    Multi-AZ
    • Preferred: Deployment pods of the add-on will be preferentially scheduled to nodes in different AZs. If all the nodes in the cluster are deployed in the same AZ, the pods will be scheduled to that AZ.
    • Required: Deployment pods of the add-on will be forcibly scheduled to nodes in different AZs. If there are fewer AZs than pods, the extra pods will fail to run.
    The everest add-on contains the everest-csi-controller and everest-csi-driver components. For details, see Components.
    After you select the add-on specification, the requested CPU and memory of the add-on component are displayed. For details, see Table 2.
    In non-typical scenarios, the formulas for estimating the limit values are as follows:
    • everest-csi-controller
      • CPU limit: 250m for 200 or fewer nodes, 350m for 1000 nodes, and 500m for 2000 nodes
      • Memory limit = (200 MiB + Number of nodes x 1 MiB + Number of PVCs x 0.2 MiB) x 1.2
    • everest-csi-driver
      • CPU limit: 300 m for 200 or fewer nodes, 500 m for 1000 nodes, and 800 m for 2000 nodes
      • Memory limit: 300 MiB for 200 or fewer nodes, 600 MiB for 1000 nodes, and 900 MiB for 2000 nodes
    Table 2 Recommended configuration limits in typical scenarios
    Configuration Scenario
    everest-csi-driver
    Nodes
    PVs/PVCs
    Add-on Instances
    CPU (The limit value is the same as the requested value.)
    Memory (The limit value is the same as the requested value.)
    50
    1000
    2
    250m
    600Mi
    300m
    300Mi
    200
    1000
    2
    250m
    1Gi
    300m
    300Mi
    1000
    1000
    2
    350m
    2Gi
    500m
    600Mi
    1000
    5000
    2
    450m
    3Gi
    500m
    600Mi
    2000
    5000
    2
    550m
    4Gi
    800m
    900Mi
    2000
    10,000
    2
    650m
    5Gi
    800m
    900Mi
  3. Configure the add-on parameters.
    Table 3 Add-on parameters
    csi_attacher_worker_threads
    Number of worker nodes that can concurrently attach EVS volumes. The default value is 60.
    csi_attacher_detach_worker_threads
    Number of worker nodes that can concurrently detach EVS volumes. The default value is 60.
    volume_attaching_flow_ctrl
    Maximum number of EVS volumes that can be attached by the everest add-on within 1 minute. The default value is 0, indicating that the performance of attaching EVS volumes is determined by the underlying storage resources.
    cluster_id
    Cluster ID
    default_vpc_id
    ID of the VPC to which the cluster belongs
    disable_auto_mount_secret
    Whether the default AK/SK can be used when an object bucket or parallel file system is mounted. The default value is false.
    enable_node_attacher
    Whether to enable the attacher on the agent to process the VolumeAttachment.
    flow_control
    This field is left blank by default. You do not need to configure this parameter.
    over_subscription
    Overcommitment ratio of the local storage pool (local_storage). The default value is 80. If the size of the local storage pool is 100 GB, it can be overcommitted to 180 GB.
    project_id
    ID of the project to which a cluster belongs
    In everest 1.2.26 or later, the performance of attaching a large number of EVS volumes has been optimized. The following parameters can be configured:
    • csi_attacher_worker_threads
    • csi_attacher_detach_worker_threads
    • volume_attaching_flow_ctrl
    The preceding parameters are associated with each other and are constrained by the underlying storage resources in the region where the cluster is located. To attach a large number of volumes (more than 500 EVS volumes per minute), contact customer service and configure the parameters under their guidance to prevent the everest add-on from running abnormally due to improper parameter settings.
  4. Click Install.
Components
Table 4 everest components
Container Component
Resource Type
Used to create, delete, snapshot, expand, attach, and detach storage volumes. If the cluster version is 1.19 or later and the add-on version is 1.2.x, the pod of the everest-csi-controller component also has an everest-localvolume-manager container by default. This container manages the creation of LVM storage pools and local PVs on the node.
Deployment
everest-csi-driver
Used to mount and unmount PVs and resize file systems. If the add-on version is 1.2.x and the region where the cluster is located supports node-attacher, the pod of the everest-csi-driver component also contains an everest-node-attacher container. This container is responsible for distributed EVS attaching. This configuration item is available in some regions.
DaemonSet
