Situation Awareness
Dynamically Mounting an EVS Disk to a StatefulSet
Updated on 2024-01-26 GMT+08:00
Application Scenarios
Dynamic mounting is available only for creating a StatefulSet. It is implemented through a volume claim template (volumeClaimTemplates field) and depends on the storage class to dynamically provision PVs. In this mode, each pod in a multi-pod StatefulSet is associated with a unique PVC and PV. After a pod is rescheduled, the original data can still be mounted to it based on the PVC name. In the common mounting mode for a Deployment, if ReadWriteMany is supported, multiple pods of the Deployment will be mounted to the same underlying storage.
  • You have created a cluster and installed the CSI add-on (everest) in the cluster.
  • If you want to create a cluster using commands, use kubectl to connect to the cluster. For details, see Connecting to a Cluster Using kubectl.
(Console) Dynamically Mounting an EVS Disk
  2. In the navigation pane on the left, click Workloads. In the right pane, click the StatefulSets tab.
  3. Click Create Workload in the upper right corner. On the displayed page, click Data Storage in the Container Settings area and click Add Volume to select VolumeClaimTemplate (VTC).
  4. Click Create PVC. In the dialog box displayed, configure the PVC parameters.
    Click Create.
    PVC Type
    In this example, select EVS.
    PVC Name
    Enter the name of the PVC. After a PVC is created, a suffix is automatically added based on the number of pods. The format is <Custom PVC name>-<Serial number>, for example, example-0.
    Creation Method
    You can select Dynamically provision to create a PVC, PV, and underlying storage on the console in cascading mode.
    Storage Classes
    The storage class for EVS disks is csi-disk.
    AZ
    Select the AZ of the EVS disk. The AZ must be the same as that of the cluster node.
    An EVS disk can only be mounted to a node in the same AZ. After an EVS disk is created, its AZ cannot be changed.
    Disk Type
    Select an EVS disk type.
    Access Mode
    EVS disks support only ReadWriteOnce, indicating that a storage volume can be mounted to one node in read/write mode. For details, see Volume Access Modes.
    Capacity (GiB)
    Capacity of the requested storage volume.
    Encryption
    You can select Encryption and an encryption key to encrypt underlying storage. Only EVS disks and SFS file systems support encryption.
    Enterprise Project
    Supported enterprise projects: default, the one to which the cluster belongs, or the one specified by the storage class.
  5. Enter the path to which the volume is mounted.
    Table 1 Mounting a storage volume
    Mount Path
    Enter a mount path, for example, /tmp.
    This parameter indicates the container path to which a data volume will be mounted. Do not mount the volume to a system directory such as / or /var/run. Otherwise, errors will occur in containers. Mount the volume to an empty directory. If the directory is not empty, ensure that there are no files that affect container startup. Otherwise, the files will be replaced, causing container startup failures or workload creation failures.
    NOTICE:
    If a volume is mounted to a high-risk directory, use an account with minimum permissions to start the container. Otherwise, high-risk files on the host machine may be damaged.
    Subpath
    Enter a subpath, for example, tmp, indicating that data in the mount path of the container will be stored in the tmp folder of the volume.
    A subpath is used to mount a local volume so that the same data volume is used in a single pod. If this parameter is left blank, the root path is used by default.
    Permission
    • Read-only: You can only read the data in the mounted volumes.
    • Read/Write: You can modify the data volumes mounted to the path. Newly written data is not migrated if the container is migrated, which may cause data loss.
    In this example, the disk is mounted to the /data path of the container. The container data generated in this path is stored in the EVS disk.
  6. Dynamically mount and use storage volumes. For details about other parameters, see Creating a StatefulSet. After the configuration, click Create Workload.
    After the workload is created, the data in the container mount directory will be persistently stored. Verify the storage by referring to Verifying Data Persistence.
(kubectl) Using an Existing EVS Disk
  1. Use kubectl to connect to the cluster.
  2. Create a file named statefulset-evs.yaml. In this example, the EVS volume is mounted to the /data path.
    apiVersion: apps/v1
    kind: StatefulSet
      namespace: default
      selector:
        matchLabels:
          app: statefulset-evs
      template:
          labels:
          containers:
            - name: container-1
              image: nginx:latest
              volumeMounts:
                - name: pvc-disk           # The value must be the same as that in the volumeClaimTemplates field.
                  mountPath: /data         # Location where the storage volume is mounted.
          imagePullSecrets:
            - name: default-secret
      serviceName: statefulset-evs         # Headless Service name.
      replicas: 2
      volumeClaimTemplates:
        - apiVersion: v1
          kind: PersistentVolumeClaim
            namespace: default
            annotations:
              everest.io/disk-volume-type: SAS    # EVS disk type.
              everest.io/crypt-key-id: <your_key_id>    # (Optional) Encryption key ID. Mandatory for an encrypted disk.
              everest.io/enterprise-project-id: <your_project_id>  # (Optional) Enterprise project ID. If an enterprise project is specified, use the same enterprise project when creating a PVC. Otherwise, the PVC cannot be bound to a PV.
            labels:
              failure-domain.beta.kubernetes.io/region: <your_region>   # Region of the node where the application is to be deployed.
              failure-domain.beta.kubernetes.io/zone: <your_zone>       # AZ of the node where the application is to be deployed.
            accessModes:
              - ReadWriteOnce               # The value must be ReadWriteOnce for EVS disks.
            resources:
              requests:
                storage: 10Gi             # EVS disk capacity, ranging from 1 to 32768.
            storageClassName: csi-disk    # Storage class type for EVS disks.
    apiVersion: v1
    kind: Service
      name: statefulset-evs   # Headless Service name.
      namespace: default
      labels:
      selector:
      clusterIP: None
      ports:
        - name: statefulset-evs
          targetPort: 80
          nodePort: 0
          port: 80
          protocol: TCP
      type: ClusterIP
    Table 2 Key parameters
    Mandatory
    Yes
    Region where the cluster is located.
    For details about the value of region, see Regions and Endpoints.
    Yes
    AZ where the EVS volume is created. It must be the same as the AZ planned for the workload.
    For details about the value of zone, see Regions and Endpoints.
    Yes
    EVS disk type. All letters are in uppercase.
    • SATA: common I/O
    • SAS: high I/O
    • SSD: ultra-high I/O
    No
    Mandatory when the EVS disk is encrypted. Enter the encryption key ID selected during EVS disk creation.
    To obtain the encryption key ID, log in to the Cloud Server Console. In the navigation pane, choose Elastic Volume Service > Disks. Click the name of the target EVS disk to go to its details page. On the Summary tab page, copy the value of KMS Key ID in the Configuration Information area.
    No
    Optional.
    Enterprise project ID of the EVS disk. If an enterprise project is specified, specify the same enterprise project when creating a PVC. Otherwise, the PVC cannot be bound to a PV.
    To obtain the enterprise project ID, log in to the Cloud Server Console. In the navigation pane, choose Elastic Volume Service > Disks. Click the name of the target EVS disk to go to its details page. On the Summary tab page, click the enterprise project in Management Information to access the enterprise project console. Copy the corresponding ID to obtain the ID of the enterprise project to which the EVS disk belongs.
    storage
    Yes
    Requested PVC capacity, in Gi. The value ranges from 1 to 32768.
    storageClassName
    Yes
    The storage class name for EVS disks is csi-disk.
  3. Run the following command to create a workload to which the EVS volume is mounted:
    kubectl apply -f statefulset-evs.yaml
  1. View the deployed application and EVS volume files.
    1. Run the following command to view the created pod:
      kubectl get pod | grep statefulset-evs
      Expected output:
      statefulset-evs-0          1/1     Running   0             45s
      statefulset-evs-1          1/1     Running   0             28s
    2. Run the following command to check whether the EVS volume has been mounted to the /data path:
      kubectl exec statefulset-evs-0 -- df | grep data
      Expected output:
      /dev/sdd              10255636     36888  10202364   0% /data
    3. Run the following command to view the files in the /data path:
      kubectl exec statefulset-evs-0 -- ls /data
      Expected output:
      lost+found
  2. Run the following command to create a file named static in the /data path:
    kubectl exec statefulset-evs-0 --  touch /data/static
    Expected output:
    lost+found
    static
  4. Run the following command to delete the pod named web-evs-auto-0:
    kubectl delete pod statefulset-evs-0
    Expected output:
    pod "statefulset-evs-0" deleted
  5. After the deletion, the StatefulSet controller automatically creates a replica with the same name. Run the following command to check whether the files in the /data path have been modified:
    Expected output:
    lost+found
    static
    If the static file still exists, the data in the EVS volume can be stored persistently.
Related Operations
You can also perform the operations listed in Table 3.
Table 3 Related operations
Operation
Expanding the capacity of an EVS disk
Quickly expand the capacity of a mounted EVS disk on the CCE console.
  1. Choose Storage from the navigation pane, and click the PersistentVolumeClaims (PVCs) tab. Click More in the Operation column of the target PVC and select Scale-out.
  2. Enter the capacity to be added and click OK.
Viewing events
You can view event names, event types, number of occurrences, Kubernetes events, first occurrence time, and last occurrence time of the PVC or PV.
  1. Choose Storage from the navigation pane, and click the PersistentVolumeClaims (PVCs) or PersistentVolumes (PVs) tab.
  2. Click View Events in the Operation column of the target PVC or PV to view events generated within one hour (event data is retained for one hour).
Viewing a YAML file
You can view, copy, and download the YAML files of a PVC or PV.
  2. Click View YAML in the Operation column of the target PVC or PV to view or download the YAML.
