Updated on 2025-11-06 GMT+08:00
Optimizing NGINX Ingress Controller in High-Traffic Scenarios
Ingress objects provide Layer 7 protocols like HTTP and HTTPS for clusters. Among the available options, Nginx ingresses are widely used. CCE has developed a featured open-source add-on called NGINX Ingress Controller, which is an enhanced version of the community solution. This add-on offers advanced Layer 7 load balancing features. In high-concurrency scenarios, the pre-allocated resources such as CPU and memory and network connections of the add-on may not be robust enough to handle the application needs. This can affect the application performance. This section describes how to optimize NGINX Ingress Controller in high-traffic scenarios.
The optimization involves the rolling upgrade of the NGINX ingress container. You are advised to perform the optimization during off-peak hours.
The NGINX Ingress Controller add-on has been installed in the target cluster.
Suggestions
The following provides some suggestions on optimizing the NGINX Ingress Controller add-on in high-traffic scenarios.
