Help Center>
Cloud Container Engine>
User Guide (Paris Regions)>
Node Pools>
Managing a Node Pool>
Copying a Node Pool
Updated on 2024-01-26 GMT+08:00
Copying a Node Pool
You can copy the configuration of an existing node pool to create a new node pool on the CCE console.
- Log in to the CCE console.
- Click the cluster name to access the cluster console. Choose Nodes in the navigation pane and click the Node Pools tab on the right.
- Choose More > Copy in the Operation column of the target node pool.
- The configurations of the selected node pool are replicated to the Clone Node Pool page. You can edit the configurations as required. For details about configuration items, see Creating a Node Pool. After confirming the configuration, click Next: Confirm.
- On the Confirm page, confirm the node pool configuration and click Submit. Then, a new node pool is created based on the edited configuration.
Parent topic: Managing a Node Pool
