Configuring OBS Mount Options
This section describes how to configure OBS volume mount options. You can configure mount options in a PV and bind the PV to a PVC. Alternatively, configure mount options in a StorageClass and use the StorageClass to create a PVC. In this way, PVs can be dynamically created and inherit mount options configured in the StorageClass by default.
The CCE Container Storage (Everest) version must be 1.2.8 or later. This add-on identifies the mount options and transfers them to the underlying storage resources. The parameter settings take effect only if the underlying storage resources support the specified options.
Notes and Constraints
Mount options cannot be configured for secure containers.
OBS Mount Options
When mounting an OBS volume, the Everest add-on presets the options described in Table 1 and Table 2 by default. The options in Table 1 are mandatory.
| Parameter | Supported Object StorageClass | Value | Description |
| use_ino | Parallel file system | Blank | If enabled, obsfs allocates the inode number. Enabled by default in read/write mode. |
| big_writes | Parallel file system Object bucket | Blank | If enabled, the maximum size of the write cache can be changed. |
| nonempty | Parallel file system Object bucket | Blank | Allows non-empty mount paths. |
| allow_other | Parallel file system Object bucket | Blank | Allows other users to access the mount directory. |
| no_check_certificate | Parallel file system Object bucket | Blank | Disables server certificate verification. |
| enable_noobj_cache | Object bucket | Blank | Enables cache entries for objects that do not exist, which can improve performance. Enabled by default in object bucket read/write mode. This option is no longer configured by default since Everest 1.2.40. |
| sigv2 | Object bucket | Blank | Specifies the signature version. Used by default in object buckets. |
| public_bucket | Object bucket | 1 | If this parameter is set to 1, public buckets are mounted anonymously. Enabled by default in object bucket read-only mode. |
| compat_dir | Object bucket | Blank | This parameter is automatically added when s3fs v1.92 is used. Multi-level directory objects in a bucket can be displayed. |
| max_write | Parallel file system Object bucket | 131072 | This parameter is valid only when big_writes is configured. The recommended value is 128 KB. |
| multipart_size | Object bucket | 20 | If a file is uploaded in multiple parts, the size of each part, measured in MB, will affect the size of the file that can be uploaded. |
| ssl_verify_hostname | Parallel file system Object bucket | 0 | Disables SSL certificate verification based on the host name. If this parameter is set to 1, SSL verification is enabled. Ensure the OBS server certificate is issued by a trusted CA. Otherwise, volume mounting will fail. |
| max_background | Parallel file system Object bucket | 100 | Allows setting the maximum number of waiting requests in the background. Used by default in parallel file systems. |
| umask | Parallel file system Object bucket | 0 | Mask of the configuration file permission. For example, if the umask value is 022, the directory permission (the maximum permission is 777) is 755 (777 - 022 = 755, rwxr-xr-x). |
Configuring Mount Options
You can configure mount options using one of the following methods.
You can use the mountOptions field to configure mount options in a PV. The options you can configure in mountOptions are listed in OBS Mount Options.
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Configure mount options in a PV. Example:
apiVersion: v1 kind: PersistentVolume metadata: annotations: pv.kubernetes.io/provisioned-by: everest-csi-provisioner everest.io/reclaim-policy: retain-volume-only # (Optional) The underlying volume is retained when the PV is deleted. name: pv-obs # PV name spec: accessModes: - ReadWriteMany # Access mode. The value must be ReadWriteMany for OBS. capacity: storage: 1Gi # Storage capacity. This parameter is only for verification. It must not be empty or 0, but the specified size will not take effect. csi: driver: obs.csi.everest.io # Dependent storage driver for the mounting fsType: obsfs # Instance type volumeHandle: <your_volume_id> # Name of the OBS volume volumeAttributes: storage.kubernetes.io/csiProvisionerIdentity: everest-csi-provisioner everest.io/obs-volume-type: STANDARD everest.io/region: <your_region> # Region where the OBS volume is everest.io/enterprise-project-id: <your_enterprise_project_id> # (Optional) Enterprise project ID of an OBS volume. This parameter is available only for enterprise accounts with enterprise projects enabled. If an enterprise project is specified, you must specify the same enterprise project when creating a PVC. Otherwise, the PVC cannot bind to a PV. nodePublishSecretRef: # Custom secret of the OBS volume name: <your_secret_name> # Custom secret name namespace: <your_namespace> # Namespace of the custom secret persistentVolumeReclaimPolicy: Retain # Reclaim policy storageClassName: csi-obs # StorageClass name mountOptions: # Mount options - umask=027 - After creating a PV, you can create a PVC, bind it to the PV, and mount the PV to the containers in the workload. For details, see Using an Existing OBS Bucket Through a Static PV.
- Check whether the mount options are effective.
In this example, the PVC is mounted to the workload that uses the nginx:latest image. You can log in to the node where the pod to which the OBS volume is mounted resides and view the progress details.
Run the following command:- Object bucket: ps -ef | grep s3fs
root 22142 1 0 Jun03 ? 00:00:00 /usr/bin/s3fs {your_obs_name} /mnt/paas/kubernetes/kubelet/pods/{pod_uid}/volumes/kubernetes.io~csi/{your_pv_name}/mount -o url=https://{endpoint}:443 -o endpoint={region} -o passwd_file=/opt/everest-host-connector/***_obstmpcred/{your_obs_name} -o nonempty -o big_writes -o sigv2 -o allow_other -o no_check_certificate -o ssl_verify_hostname=0 -o umask=027 -o max_write=131072 -o multipart_size=20 - Parallel file system: ps -ef | grep obsfs
root 1355 1 0 Jun03 ? 00:03:16 /usr/bin/obsfs {your_obs_name} /mnt/paas/kubernetes/kubelet/pods/{pod_uid}/volumes/kubernetes.io~csi/{your_pv_name}/mount -o url=https://{endpoint}:443 -o endpoint={region} -o passwd_file=/opt/everest-host-connector/***_obstmpcred/{your_obs_name} -o allow_other -o nonempty -o big_writes -o use_ino -o no_check_certificate -o ssl_verify_hostname=0 -o max_background=100 -o umask=027 -o max_write=131072
You can use mountOptions to configure mount options in a StorageClass. The options you can configure in mountOptions are listed in OBS Mount Options.
- Create a custom StorageClass. Example:
kind: StorageClass apiVersion: storage.k8s.io/v1 metadata: name: csi-obs-mount-option provisioner: everest-csi-provisioner parameters: csi.storage.k8s.io/csi-driver-name: obs.csi.everest.io csi.storage.k8s.io/fstype: s3fs everest.io/obs-volume-type: STANDARD reclaimPolicy: Delete volumeBindingMode: Immediate mountOptions: # Mount options - umask=027
- After the StorageClass is configured, you can use it to create a PVC. By default, dynamically created PVs inherit the mount options configured in the StorageClass. For details, see Using an OBS Bucket Through a Dynamic PV.
