Logging In to a Node
- Before you log in to a node using SSH, ensure that the SSH port (22 by default) is enabled in the security group of the node.
- Before you log in to a node (an ECS) using SSH through the Internet, ensure that the ECS already has an EIP bound.
- Only login to a running ECS is allowed.
- Only the user root can log in to a Linux server.
Login Modes
You can log in to an ECS in either of the following modes:
- Management console (VNC)
If an ECS has no EIP, log in to the ECS console and click Remote Login in the same row as the ECS.
- SSH
This mode applies only to ECSs running Linux. Usually, you can use a remote login tool, such as PuTTY, Xshell, and SecureCRT, to log in to your ECS. If none of the remote login tools can be used, log in to the ECS console and click Remote Login in the same row as the ECS to view the connection status and running status of the ECS.
- When you use the Windows OS to log in to a Linux node, set Auto-login username to root.
- The CCE console does not support node OS upgrade. Do not upgrade the node OS using the yum update command. Otherwise, the container networking components will be unavailable.
EIP Binding |
On-Premises OS |
Connection Method |
Yes |
Windows |
Use a remote login tool, such as PuTTY or Xshell.
Yes |
Linux |
Run commands.
Yes/No |
Windows/Linux |
Remote login using the management console: Logging In to a Linux ECS Using VNC |
