Help Center>
Cloud Container Engine>
User Guide (ME-Abu Dhabi Region)>
Clusters>
Upgrading a Cluster>
Performing Post-Upgrade Verification>
New Node Check
Updated on 2024-01-04 GMT+08:00
New Node Check
Check Items
Check whether nodes can be created in the cluster.
- In the navigation pane, choose Nodes. On the displayed page, click the Nodes tab and then Create Node. For details about the node configuration, see Creating a Node.
Solution
If nodes cannot be created in your cluster after the cluster is upgraded, contact technical support.
Parent topic: Performing Post-Upgrade Verification
