Updated on 2026-09-21 GMT+08:00
Cluster Access Overview
Accessing a cluster means communicating with it and executing cluster management tasks. A CCE cluster is a distributed system consisting of multiple nodes. Resources in a cluster such as pods, Services, and Deployments need to be centrally managed and operated using various tools and methodologies. The process of accessing a cluster involves interacting with the cluster using tools such as kubectl, CloudShell, and X.509 certificates for resource creation, configuration, monitoring, and debugging.
Cluster Access Modes
You can select a proper mode to access a CCE cluster. The following table lists cluster access modes.
Table 1 Comparison between cluster access modes
Mode
Pros
Cons
Application Scenario
Accessing a Cluster Using kubectl
  • High flexibility and comprehensive functions
  • Automatic and batch operations
  • Manual configuration of the local environment and credentials
  • Credential management-based security
This mode is intended for developers and O&M personnel for daily cluster management, such as resource creation, status monitoring, and troubleshooting.
Using KooCLI and kubectl to Access a Cluster
  • No need to store static user certificates locally
  • Precise audit tracing to specific users
  • Batch burst operations not supported
Accessing a Cluster Using CloudShell
  • Rapid cluster access, without the need of configuring the local environment
  • Integrated with the cloud platform, facilitating cross-service management
  • Coupled with the cloud platform, allowing only online operations
  • Only command line operations are allowed. This is somewhat limited compared to local tools like kubectl
This mode is suitable for scenarios where temporary access to a cluster is necessary, as it eliminates the need for local tool installation and configuration.
Accessing a Cluster Using an X.509 Certificate
  • High security, preventing attacks
  • Enhanced identity authentication and data encryption
  • Complex configuration that requires certificates, keys, and related permissions
  • Complex certificate management and update
This mode is ideal for scenarios requiring secure service communication, identity authentication, and encryption.
Accessing a Cluster Using a Custom Domain Name
  • Easy-to-remember domain name, facilitating cluster access
  • Complex SAN configuration
This mode is designed for scenarios where a simple domain name instead of an IP address is used to access a cluster.
Configuring a Cluster's API Server for Internet Access
  • Comprehensive remote access capabilities
  • Cross-region and global access
  • Security measures such as firewalls, encryption, and authentication need to be taken to minimize the risk of attacks on the API server exposed to the Internet.
  • Affected by bandwidth and latency, especially in global access
This mode is ideal for managing clusters in cloud environments or across regions, particularly when access from multiple locations is required.
Revoking a Cluster Credential
CCE clusters allow you to revoke credentials. In multi-tenant scenarios, CCE generates a unique credential (such as a kubeconfig file or an X.509 certificate) for each user to access their designated cluster. These credentials contain user identity and authorization details, enabling users to perform authorized operations while ensuring secure isolation and management. However, credentials typically have a fixed validity period. If an employee resigns or a credential is compromised, manual revocation is required to maintain cluster security. For details, see Revoking a Cluster Access Credential.
