Help Center/ Cloud Container Engine/ User Guide/ Clusters/ Managing Clusters/ Changing the Billing Mode of a Cluster from Pay-per-Use to Yearly/Monthly
Updated on 2026-09-21 GMT+08:00
A cluster can be billed on a pay-per-use or yearly/monthly basis. The billing mode of a cluster can be changed from pay-per-use to yearly/monthly.
To change the billing mode of a node from pay-per-use to yearly/monthly, see Changing the Billing Mode of a Node to Yearly/Monthly.
To change the billing mode of a cluster from pay-per-use to yearly/monthly, perform the following operations:
  1. Log in to the CCE console. In the navigation pane, choose Clusters.
  2. Locate the target cluster, click ... to view more operations on the cluster, and choose Change Billing Mode.
  3. On the page displayed, select the target cluster and click OK. You can also select the nodes whose billing modes you want to change.
    Figure 1 Changing the billing mode of a cluster to yearly/monthly
  4. Wait for the resource checks and the order generation, click OK to go to the Billing Center, and submit the order.
    Figure 2 Generating an order
  5. Select the resources whose billing modes are to be changed to yearly/monthly, set the required duration, enable auto-renew, and click Pay.
    Figure 3 Changing the billing mode from pay-per-use to yearly/monthly
