Renewing a Yearly/Monthly-Billed Cluster
You can renew a yearly/monthly-billed cluster.
This section describes how to renew a cluster billed on a yearly/monthly basis.
A yearly/monthly-billed cluster will be deleted if it is not renewed after expiration, and all nodes and the running services in the cluster will be destroyed. CCE strongly recommends that you renew the cluster before it expires or enable auto renewal.
- Log in to the CCE console. In the navigation pane, choose Clusters.
- Locate the cluster to be renewed, click ... to view more operations on the cluster, and choose Renew.
Figure 1 Renewing a cluster
- On the displayed page, renew the service as prompted.
- If the selected resource (highlighted) is associated with other resources, you can decide whether you want to perform the operation on all these resources at the same time.
- If you change the resource specifications before its renewal period takes effect, the renewal period cannot be unsubscribed from.
- Renewed resources are not eligible of a 5-day unconditional unsubscription.
- Click Pay. On the page displayed, review the order amount, select a payment method, and click Pay.
- After the payment is complete, you can go back to the Orders or Renewals page to view and manage your order.
