Hibernating or Waking Up a Pay-per-Use Cluster
If a pay-per-use cluster is not needed temporarily, hibernate it to reduce costs.
After a cluster is hibernated, resources such as workloads cannot be created or managed in the cluster.
Precautions
- During cluster wakeup, the master node may fail to start due to insufficient resources. This leads to a cluster wakeup failure. In this case, wait for a while and try again.
- After a cluster is woken up, it takes 3 to 5 minutes to initialize data. Deliver services after the cluster runs properly.
Billing
- After a pay-per-use cluster is hibernated, the master node's resource fee is suspended. However, worker nodes, bound EIPs, and bandwidth in the cluster will continue to be billed according to their respective pricing modes (yearly/monthly or pay-per-use). For details about the billing of a stopped node, see Will I Be Billed After ECSs Are Stopped?
- Billing for a hibernated pay-per-use cluster resumes when it is woken up.
Hibernating a Cluster
- Log in to the CCE console. In the navigation pane, choose Clusters.
- Locate the cluster to be hibernated, click ... to view more operations on the cluster, and choose Hibernate.
     Figure 1 Hibernating a cluster
- In the dialog box displayed, check the precautions and click Yes. Wait until the cluster is hibernated.
     After a cluster is hibernated, the billing of master node resources will stop. Resources, such as worker nodes (ECSs), bound EIPs, and bandwidth, are still billed based on their own billing modes. To shut down nodes, select Shut down all nodes in the cluster in the dialog box or see Stopping a Node. Most nodes are no longer billed after they are stopped, excluding certain types of ECSs (ones with local disks attached, such as disk-intensive and ultra-high I/O ECSs). For details, see ECS Billing. Figure 2 Prompt information
Waking Up a Cluster
You can wake up a hibernated cluster as needed.
- Click Wake Up in the row of the target cluster.
- When the cluster status changes from Waking up to Running, the cluster is woken up. It takes about 3 to 5 minutes to wake up the cluster. After the cluster is woken up, the cluster management fee resumes.
