Situation Awareness
Configuring QoS for a Pod
Updated on 2024-01-04 GMT+08:00
Bandwidth preemption occurs between different containers deployed on the same node, which may cause service jitter. You can configure QoS rate limiting for inter-pod access to prevent this problem.
The following shows constraints on setting the rate limiting for inter-pod access:
Constraint Type
Tunnel network model
VPC network model
Cloud Native 2.0 Network Model
Supported versions
All versions
Clusters of v1.19.10 and later
Supported runtime types
Only common containers
Supported pod types
Only non-HostNetwork pods
Supported scenarios
Inter-pod access, pods accessing nodes, and pods accessing services
None
None
  • Pods access external cloud service CIDR blocks 100.64.0.0/10 and 214.0.0.0/8.
  • Traffic rate limiting of health check
Value range of rate limit
Only the rate limit in the unit of Mbit/s or Gbit/s is supported, for example, 100 Mbit/s and 1 Gbit/s. The minimum value is 1 Mbit/s and the maximum value is 4.29 Gbit/s.
Using the CCE Console
When creating a workload on the console, you can set pod ingress and egress bandwidth limits by clicking Network Configuration in the Advanced Settings area.
Using kubectl
You can add annotations to a workload to specify its egress and ingress bandwidth.
apiVersion: apps/v1
kind: Deployment
  namespace: default
  labels:
    app: test
  replicas: 2
  selector:
    matchLabels:
      app: test
  template:
      labels:
        app: test
      annotations:
        kubernetes.io/ingress-bandwidth: 100M
        kubernetes.io/egress-bandwidth: 100M
      containers:
        - name: container-1
          image: nginx:alpine
          imagePullPolicy: IfNotPresent
      imagePullSecrets:
        - name: default-secret
  • kubernetes.io/ingress-bandwidth: ingress bandwidth of the pod
  • kubernetes.io/egress-bandwidth: egress bandwidth of the pod
If these two parameters are not specified, the bandwidth is not limited.
After modifying the ingress or egress bandwidth limit of a pod, restart the container for the modification to take effect. After annotations are modified in a pod not managed by workloads, the container will not be restarted, so the bandwidth limits do not take effect. You can create a pod again or manually restart the container.
