Situation Awareness
On this page
Host Network
Updated on 2024-01-04 GMT+08:00
Kubernetes allows pods to directly use the host/node network. When a pod is configured with hostNetwork: true, applications running in the pod can directly view the network interface of the host where the pod is located.
Configuration
Add hostNetwork: true to the pod definition.
apiVersion: apps/v1
kind: Deployment
  replicas: 1
  selector:
    matchLabels:
      app: nginx
  template:
      labels:
        app: nginx
      hostNetwork: true
      containers:
      - image: nginx:alpine
      imagePullSecrets:
      - name: default-secret
The configuration succeeds if the pod IP is the same as the node IP.
$ kubectl get pod -owide
NAME                    READY   STATUS    RESTARTS   AGE     IP          NODE        NOMINATED NODE   READINESS GATES
nginx-6fdf99c8b-6wwft   1/1     Running   0          3m41s   10.1.0.55   10.1.0.55   <none>           <none>
Precautions
If a pod uses the host network, it occupies a host port. The pod IP is the host IP. To use the host network, you must confirm pods do not conflict with each other in terms of the host ports they occupy. Do not use the host network unless you know exactly which host port is used by which pod.
When using the host network, you access the node to access a pod on it. Therefore, allow access from the security group port of the node. Otherwise, the access fails.
In addition, using the host network requires you to reserve host ports for the pods. When using a Deployment to deploy pods of the hostNetwork type, ensure that the number of pods does not exceed the number of nodes. Otherwise, multiple pods will be scheduled onto the node, and they will fail to start due to port conflicts. For example, in the preceding example nginx YAML, if two pods (setting replicas to 2) are deployed in a cluster with only one node, one pod cannot be created. The pod logs will show that the Nginx cannot be started because the port is occupied.
CAUTION:
Do not schedule multiple pods that use the host network on the same node. Otherwise, when a ClusterIP Service is created to access a pod, the cluster IP address cannot be accessed.
$ kubectl get deploy
NAME    READY   UP-TO-DATE   AVAILABLE   AGE
nginx   1/2     2            1           67m
$ kubectl get pod
nginx-6fdf99c8b-6wwft   1/1     Running            0          67m
nginx-6fdf99c8b-rglm7   0/1     CrashLoopBackOff   13         44m
$ kubectl logs nginx-6fdf99c8b-rglm7
/docker-entrypoint.sh: /docker-entrypoint.d/ is not empty, will attempt to perform configuration
/docker-entrypoint.sh: Looking for shell scripts in /docker-entrypoint.d/
/docker-entrypoint.sh: Launching /docker-entrypoint.d/10-listen-on-ipv6-by-default.sh
10-listen-on-ipv6-by-default.sh: info: Getting the checksum of /etc/nginx/conf.d/default.conf
10-listen-on-ipv6-by-default.sh: info: Enabled listen on IPv6 in /etc/nginx/conf.d/default.conf
/docker-entrypoint.sh: Launching /docker-entrypoint.d/20-envsubst-on-templates.sh
/docker-entrypoint.sh: Launching /docker-entrypoint.d/30-tune-worker-processes.sh
/docker-entrypoint.sh: Configuration complete; ready for start up
2022/05/11 07:18:11 [emerg] 1#1: bind() to 0.0.0.0:80 failed (98: Address in use)
nginx: [emerg] bind() to 0.0.0.0:80 failed (98: Address in use)
2022/05/11 07:18:11 [emerg] 1#1: bind() to [::]:80 failed (98: Address in use)
nginx: [emerg] bind() to [::]:80 failed (98: Address in use)
2022/05/11 07:18:11 [emerg] 1#1: still could not bind()
nginx: [emerg] still could not bind()
