Configuring an HTTPS Certificate for a LoadBalancer Ingress
Ingresses support TLS certificates and secure your Services with HTTPS.
You can use a TLS secret certificate configured in the cluster and the ELB certificate.
![](https://support.huaweicloud.com/intl/en-us/my-kualalumpur-1-usermanual-cce/public_sys-resources/note_3.0-en-us.png)
If HTTPS is enabled for the same port of the same load balancer of multiple ingresses, you must select the same certificate.
Using a TLS Secret Certificate
- Use kubectl to connect to the cluster. For details, see Connecting to a Cluster Using kubectl.
- Ingress supports two TLS secret types: kubernetes.io/tls and IngressTLS. IngressTLS is used as an example. For details, see Creating a Secret. For details about examples of the kubernetes.io/tls secret and its description, see TLS secrets.
Create a YAML file named ingress-test-secret.yaml. The file name can be customized.
vi ingress-test-secret.yaml
The YAML file is configured as follows:apiVersion: v1 data: tls.crt: LS0******tLS0tCg== tls.key: LS0tL******0tLS0K kind: Secret metadata: annotations: description: test for ingressTLS secrets name: ingress-test-secret namespace: default type: IngressTLS
In the preceding information, tls.crt and tls.key are only examples. Replace them with the actual files. The values of tls.crt and tls.key are Base64-encoded.
- Create a secret.
kubectl create -f ingress-test-secret.yaml
If information similar to the following is displayed, the secret has been created:
secret/ingress-test-secret created
View the created secret.
kubectl get secrets
NAME TYPE DATA AGE ingress-test-secret IngressTLS 2 13s
- Create a YAML file named ingress-test.yaml. The file name can be customized.
vi ingress-test.yaml
Default security policy (kubernetes.io/elb.tls-ciphers-policy) is supported only in clusters of v1.17.17 or later.
The following uses the automatically created load balancer as an example. The YAML file is configured as follows:
For clusters of v1.21 or earlier:
apiVersion: networking.k8s.io/v1beta1 kind: Ingress metadata: name: ingress-test annotations: kubernetes.io/elb.class: performance kubernetes.io/ingress.class: cce kubernetes.io/elb.port: '443' kubernetes.io/elb.autocreate: '{ "type": "public", "bandwidth_name": "cce-bandwidth-******", "bandwidth_chargemode": "bandwidth", "bandwidth_size": 5, "bandwidth_sharetype": "PER", "eip_type": "5_bgp", "available_zone": [ "" ], "elb_virsubnet_ids":["b4bf8152-6c36-4c3b-9f74-2229f8e640c9"], "l7_flavor_name": "L7_flavor.elb.s1.small" }' kubernetes.io/elb.tls-ciphers-policy: tls-1-2 spec: tls: - secretName: ingress-test-secret rules: - host: foo.bar.com http: paths: - path: '/' backend: serviceName: <your_service_name> # Replace it with the name of your target Service. servicePort: 80 property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH
For clusters of v1.23 or later:apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test annotations: kubernetes.io/elb.class: performance kubernetes.io/elb.port: '443' kubernetes.io/elb.autocreate: '{ "type": "public", "bandwidth_name": "cce-bandwidth-******", "bandwidth_chargemode": "bandwidth", "bandwidth_size": 5, "bandwidth_sharetype": "PER", "eip_type": "5_bgp", "available_zone": [ "" ], "elb_virsubnet_ids":["b4bf8152-6c36-4c3b-9f74-2229f8e640c9"], "l7_flavor_name": "L7_flavor.elb.s1.small" }' kubernetes.io/elb.tls-ciphers-policy: tls-1-2 spec: tls: - secretName: ingress-test-secret rules: - host: foo.bar.com http: paths: - path: '/' backend: service: name: <your_service_name> # Replace it with the name of your target Service. port: number: 8080 # Replace 8080 with the port number of your target Service. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: cce
Table 1 Key parameters Parameter
Mandatory
Type
No
String
The default value is tls-1-2, which is the default security policy used by the listener and takes effect only when HTTPS is used.
Options:
- tls-1-0
- tls-1-1
- tls-1-2
- tls-1-2-strict
For details of cipher suites for each security policy, see Table 2.
tls
No
Array of strings
When HTTPS is used, this parameter must be added to specify the secret certificate.
Multiple independent domain names and certificates can be added. For details, see Configuring SNI for a LoadBalancer Ingress.
secretName
No
String
This parameter is mandatory if HTTPS is used. Set this parameter to the name of the created secret.
Table 2 tls_ciphers_policy parameter description Security Policy
TLS Version
Cipher Suite
tls-1-0
TLS 1.2
TLS 1.1
TLS 1.0
ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:AES128-GCM-SHA256:AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:AES128-SHA256:AES256-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES128-SHA:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:AES128-SHA:AES256-SHA
tls-1-1
TLS 1.2
TLS 1.1
tls-1-2
TLS 1.2
tls-1-2-strict
TLS 1.2
- Create an ingress.
If information similar to the following is displayed, the ingress has been created.
ingress/ingress-test created
View the created ingress.
kubectl get ingress
If information similar to the following is displayed, the ingress has been created and the workload is accessible.
NAME HOSTS ADDRESS PORTS AGE ingress-test * 121.**.**.** 80 10s
- Enter https://121.**.**.**:443 in the address box of the browser to access the workload (for example, Nginx workload).
121.**.**.** indicates the IP address of the unified load balancer.
Using the ELB Certificate
To use the ELB certificate, you can specify the annotations kubernetes.io/elb.tls-certificate-ids.
- If you specify both the IngressTLS certificate and the ELB certificate, the latter is used.
- CCE does not check whether the ELB certificate is valid. It only checks whether the certificate exists.
- Only clusters of v1.19.16-r2, v1.21.5-r0, v1.23.3-r0, or later support the ELB certificate.
apiVersion: networking.k8s.io/v1beta1 kind: Ingress metadata: name: ingress-test annotations: kubernetes.io/ingress.class: cce kubernetes.io/elb.port: '443' kubernetes.io/elb.id: 0b9a6c4d-bd8b-45cc-bfc8-ff0f9da54e95 kubernetes.io/elb.class: union kubernetes.io/elb.tls-certificate-ids: 058cc023690d48a3867ad69dbe9cd6e5,b98382b1f01c473286653afd1ed9ab63 spec: rules: - host: '' http: paths: - path: '/' backend: serviceName: <your_service_name> # Replace it with the name of your target Service. servicePort: 80 property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH
apiVersion: networking.k8s.io/v1 kind: Ingress metadata: name: ingress-test namespace: default annotations: kubernetes.io/elb.port: '443' kubernetes.io/elb.id: 0b9a6c4d-bd8b-45cc-bfc8-ff0f9da54e95 kubernetes.io/elb.class: union kubernetes.io/elb.tls-certificate-ids: 058cc023690d48a3867ad69dbe9cd6e5,b98382b1f01c473286653afd1ed9ab63 spec: rules: - host: '' http: paths: - path: '/' backend: service: name: <your_service_name> # Replace it with the name of your target Service. port: number: 8080 # Replace 8080 with the port number of your target Service. property: ingress.beta.kubernetes.io/url-match-mode: STARTS_WITH pathType: ImplementationSpecific ingressClassName: cce
Parameter |
Type |
Description |
kubernetes.io/elb.tls-certificate-ids |
String |
ELB certificate IDs, which are separated by comma (,). The list length is greater than or equal to 1. The first ID in the list is the server certificate, and the other IDs are SNI certificates in which a domain name must be contained. If an SNI certificate cannot be found based on the domain name requested by the client, the server certificate will be returned by default. To obtain the certificate, log in to the CCE console, choose Service List > Networking > Elastic Load Balance, and click Certificates in the navigation pane. In the load balancer list, copy the ID under the target certificate name. |
