Using Dashboards
A dashboard integrates high-frequency monitoring metrics of different components from different perspectives. Different metrics are displayed on the same screen in charts, helping you monitor the cluster running in real time.
The dashboard displays monitoring metrics in various views such as the cluster view, API server view, pod view, host view, and node view.
- The cluster version is later than v1.17.
- The cluster is in the Running state.
- Monitoring Center has been enabled for the cluster.
Checking and Switching Views
- In the navigation pane, choose Monitoring Center. Click the Dashboard tab.
The cluster view is displayed by default.
- The dashboard provides preset views. You can click the Switch View button next to the view name to select monitoring data to view.
- Configure related parameters for checking views.
- Specify the view window.
Select or customize time segments in the upper right corner of the page, and click
to refresh the page.
