Updated on 2026-09-21 GMT+08:00
Cluster View
A cluster view is generated based on metrics and Prometheus Query Language (PromQL) statements. It displays information about nodes, CPUs, memory, networks, and disks, so you can better monitor a cluster. The following describes cluster resources from two parts: metric description and metric list. In the resource diagrams, greater values in bytes can be converted to ones in MB, KB, or GB.
Metric Description
Cluster metrics include basic metrics, network metrics, and disk metrics. You can view these metrics in the following tables.
Figure 1 Basic metrics
Table 1 Basic metrics
Metric
Unit
Nodes
N/A
The number of nodes in a cluster.
Nodes with Unavailable Disks
N/A
The number of nodes with unavailable disks in a cluster.
Nodes Unavailable
N/A
The number of unready nodes in a cluster.
CPU Usage
Total CPUs used by all containers/CPU limits in the cluster
CPU Requests Commitment
Total CPU requests/Total CPU of the cluster
CPU Limits Commitment
Total CPU limits/Total CPU of the cluster
Memory Usage
Total memory used by all containers/Memory limits in the cluster
Memory Requests Commitment
Total memory requests/Total memory of the cluster
Memory Limits Commitment
Memory limits/Total memory of the cluster
Pods
N/A
The number of pods in different states (Failed, Pending, Running, Succeeded, and Unknown) in a cluster.
N/A
The number of containers in different states (Running, Waiting, and Terminated) in a cluster.
Used CPU
core
Total CPUs used by all containers in each namespace.
Used Memory
byte
Total memory used by all containers in each namespace.
Figure 2 Network metrics
Table 2 Network metrics
Metric
Unit
Network Receive Rate
byte/s
Total number of bytes received by all containers in each namespace per second.
Network Transmit Rate
byte/s
Total number of bytes sent by all containers in each namespace per second.
Average Network Receive Rate
byte/s
Average number of bytes received by all containers in each namespace per second.
Average Network Transmit Rate
byte/s
Average number of bytes sent by all containers in each namespace per second.
Rate of Received Packets
N/A
Total number of packets received by all containers in each namespace per second.
Rate of Transmitted Packets
N/A
Total number of packets sent by all containers in each namespace per second.
Packet Loss (Receive)
N/A
Total number of packets not received by all containers in each namespace per second.
Packet Loss (Transmit)
N/A
Total number of packets sent from all containers but not received by the receiver in each namespace per second.
Figure 3 Disk metrics
Table 3 Disk metrics
Metric
Unit
Disk I/O Rate (Read + Write)
N/A
Total number of read and write operations on the disk by all containers in each namespace per second.
Disk Throughput (Read + Write)
byte/s
Total number of bytes read from and written to the disk by all containers in each namespace per second.
Metric List
The following is the metric list of the cluster view.
Table 4 Metric description
Metric
Type
kube_pod_container_resource_requests
Gauge
Resource requests of a container.
kube_pod_container_resource_limits
Gauge
Resource limits of a container.
kube_node_status_allocatable
Gauge
Resources allocatable on a node.
kube_pod_status_phase
Gauge
The current phase of a pod.
node_memory_MemAvailable_bytes
Gauge
The amount of memory available on a node.
node_memory_MemTotal_bytes
Gauge
Cumulative count of bytes that can be consumed by a node.
node_cpu_seconds_total
Counter
Seconds the CPUs spent in each mode.
kube_node_info
Gauge
Node information.
kube_node_status_condition
Gauge
Node status.
kube_pod_container_status_waiting
Gauge
Whether the container is in the waiting state.
kube_pod_container_status_terminated
Gauge
Whether the container is in the terminated state.
container_cpu_usage_seconds_total
Counter
Cumulative CPU time consumed by a container, in seconds.
container_memory_rss
Gauge
Resident set size (RSS), which is the amount of space of physical memory (RAM) held by a process.
container_network_receive_bytes_total
Counter
Cumulative count of bytes received by a container.
container_network_transmit_bytes_total
Counter
Cumulative count of bytes sent by a container.
container_network_receive_packets_total
Counter
Cumulative count of packets received by a container.
container_network_transmit_packets_total
Counter
Cumulative count of packets sent by a container.
container_network_receive_packets_dropped_total
Counter
Cumulative count of packets not received by a container.
container_network_transmit_packets_dropped_total
Counter
Cumulative count of packets sent from a container but not received by the receiver.
container_fs_reads_total
Counter
Cumulative count of reads completed by a container.
container_fs_reads_bytes_total
Counter
Cumulative count of bytes read by a container.
