CIDR Block of the Cluster Management Plane
Check Items
Check whether the CIDR block of the cluster management plane is the same as that configured on the backbone network.
The CIDR block of the management plane has been modified in your region. As a result, the CIDR block of the management plane and that configured on the backbone network are inconsistent.
Submit a service ticket to contact technical support to modify the settings, and recheck the configurations.
