Help Center/ Cloud Container Engine/ User Guide/ Networking/ Services/ LoadBalancer/ Network and Backend Configuration/ Configuring Health Check on Multiple LoadBalancer Service Ports
Updated on 2026-09-21 GMT+08:00
The health check annotation for LoadBalancer Services has been upgraded from kubernetes.io/elb.health-check-option to kubernetes.io/elb.health-check-options. You can now configure health checks for specific Service ports without affecting other ports. To apply a global health check to all ports, continue using the original annotation.
  • This function is available in the following versions:
    • v1.19: v1.19.16-r5 or later
    • v1.21: v1.21.8-r0 or later
    • v1.23: v1.23.6-r0 or later
    • v1.25: v1.25.2-r0 or later
    • Versions later than v1.25
  • Either kubernetes.io/elb.health-check-option or kubernetes.io/elb.health-check-options can be configured.
  • The target_service_port field is mandatory and must be unique.
Configure health checks for different Service ports. The following is an example using the kubernetes.io/elb.health-check-options annotation:
apiVersion: v1
kind: Service
  namespace: default
  labels:
    app: nginx
    version: v1
  annotations:
    kubernetes.io/elb.class: union         # Load balancer type
    kubernetes.io/elb.id: <your_elb_id>    # Load balancer ID. Replace it with the actual value.
    kubernetes.io/elb.lb-algorithm: ROUND_ROBIN  # Load balancer algorithm
    kubernetes.io/elb.health-check-flag: 'on'    # Enable ELB health check.
    kubernetes.io/elb.health-check-options: '[
		"protocol": "TCP",
		"delay": "5",
		"timeout": "10",
		"max_retries": "3",
		"target_service_port": "TCP:1",
		"monitor_port": "22"
		"protocol": "HTTP",
		"delay": "5",
		"timeout": "10",
		"max_retries": "3",
		"path": "/",
		"target_service_port": "TCP:2",
		"monitor_port": "22",
                "expected_codes": "200"
  selector:
    app: nginx
    version: v1
  externalTrafficPolicy: Cluster
  ports:
    - name: cce-service-0
      targetPort: 1
      nodePort: 0
      port: 1
      protocol: TCP
    - name: cce-service-1
      targetPort: 2
      nodePort: 0
      port: 2
      protocol: TCP
  type: LoadBalancer
  loadBalancerIP: **.**.**.**
Table 1 elb.health-check-options
Mandatory
Type
target_service_port
Yes
String
Port for health check specified by spec.ports. The value consists of the protocol and port number, for example, TCP:80.
monitor_port
No
String
Re-specified port for health check. If this parameter is not specified, the service port is used by default.
Ensure that the port is in the listening state on the node where the pod is located. Otherwise, the health check result will be affected.
delay
No
String
Health check interval (s)
Value range: 1 to 50. Default value: 5
timeout
No
String
Health check timeout, in seconds.
Value range: 1 to 50. Default value: 10
max_retries
No
String
Maximum number of health check retries.
Value range: 1 to 10. Default value: 3
protocol
No
String
Health check protocol.
Default value: protocol of the associated Service
Value options: HTTPS, TLS, gRPC, TCP, UDP, and HTTP
To use HTTPS, TLS, or gRPC, you need to use a dedicated load balancer, and the cluster version must be v1.28.15-r90, v1.29.15-r50, v1.30.14-r50, v1.31.14-r10, v1.32.9-r10, v1.33.7-r10, v1.34.3-r0, or later. gRPC and TLS depend on the ELB capabilities. Before using this function, submit a service ticket to enable the required ELB capabilities.
  • When the listener's backend protocol is UDP or QUIC, the health check protocol must be UDP.
  • When the listener's backend protocol is TCP, the health check protocol must be TCP, HTTP, or HTTPS.
  • When the listener's backend protocol is TLS, HTTP, HTTPS, or gRPC, the health check protocol must be TCP, HTTP, HTTPS, TLS, or gRPC.
CAUTION:
To change the health check protocol (including the switchover between global check and custom check), disable the health check, enable it again, and change the protocol.
path
No
String
Health check URL. This parameter needs to be configured when the protocol is HTTP, HTTPS, or gRPC.
Default value: /
Value range: 1-80 characters
expected_codes
No
String
Expected response status code. This parameter is supported only by clusters v1.19.16-r50, v1.21.11-r10, v1.23.9-r10, v1.25.4-r10, v1.27.1-r10, or later.
Value:
  • A specific value, for example, 200
  • A list of values that are separated with commas (,), for example, 200, 202
  • A value range, for example, 200–204
Default value: 200. The status code ranges from 200 to 599. For gRPC health checks, the default value is 0, and the status code ranges from 0 to 99.
This parameter is available only for HTTP, HTTPS, or gRPC. It has no effect on other protocols.
