Help Center/ Cloud Container Engine/ User Guide/ Networking/ Services/ LoadBalancer/ Network and Backend Configuration/ Configuring Weights for StatefulSet Backend Pods in a LoadBalancer Service
Updated on 2026-09-21 GMT+08:00
When accessing a Service through a load balancer, traffic is typically distributed evenly across all backend pods. However, scenarios such as allocating more traffic to high-performance pods or performing grayscale releases on newly deployed pods require uneven distribution.
To support this, add the annotation kubernetes.io/elb.custom-backend-weights to the Service's metadata.annotations to configure custom weights for specific pods (StatefulSet pods only).
  • A CCE Turbo cluster is available, as this function is not supported by other cluster types.
  • The cluster version must meet the following requirements:
    • v1.29: v1.29.15-r60 or later
    • v1.30: v1.30.14-r60 or later
    • v1.31: v1.31.14-r20 or later
    • v1.32: v1.32.9-r20 or later
    • v1.33: v1.33.7-r20 or later
    • v1.34: v1.34.3-r10 or later
    • v1.35: v1.35.1-r0 or later
    • Clusters of later versions
Using kubectl
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Create a YAML file named service-test.yaml. The file name can be customized.
    vi service-test.yaml
    The following is an example YAML file of an ingress associated with an existing load balancer:
    apiVersion: v1
    kind: Service
      labels:
        app: test-state
        version: v1
      namespace: default
      annotations:
        kubernetes.io/elb.class: performance   # Load balancer type. Only dedicated load balancers are supported.
        kubernetes.io/elb.id: <your_elb_id>   # Load balancer ID. Replace it with the actual value.
        #  Configure the weights of StatefulSet backend pods.
        kubernetes.io/elb.custom-backend-weights: |
            "defaultWeight": 12,
            "groups": [
                "listener": {
                  "protocol": "TCP",
                  "port": 978
                "statefulSets": [
                    "name": "test-state",
                    "weights": [
                        "weight": 18,
                        "podIndexes": [1]
      selector:  # The Service must be associated with StatefulSet workloads.
        app: test-state
        version: v1
      externalTrafficPolicy: Cluster
      ports:
        - name: cce-service-0
          targetPort: 80
          nodePort: 0
          port: 978
          protocol: TCP
      type: LoadBalancer
      loadBalancerIP: 192.168.0.6
    Table 1 kubernetes.io/elb.custom-backend-weights data structure
    Mandatory
    Type
    defaultWeight
    Yes
    Integer
    The default backend weight. Pods without an explicitly assigned weight will use this default value.
    Value range: 1 to 100
    groups
    No
    Array of WeightGroup Object
    Weight rule groups, where each group corresponds to the backend servers attached to a listener.
    Table 2 WeightGroup data structure
    Mandatory
    Type
    listener
    Yes
    Listener Object
    Target listener to be matched.
    statefulSets
    Yes
    Array of StatefulSet Object
    StatefulSets for which weights are to be configured.
    Table 3 Listener data structure
    Mandatory
    Type
    protocol
    Yes
    String
    Listener protocol, which must match the protocol of the Service's associated listener.
    port
    Yes
    Integer
    Listener port, which must match the port on the Service's associated listener.
    Table 4 StatefulSet data structure
    Mandatory
    Type
    name
    Yes
    String
    StatefulSet name, which must match the name of the StatefulSet actually associated with the Service.
    If none of the workloads associated with the Service matches this name, or the matched workload is not a StatefulSet, the weight configuration is ignored.
    weights
    Yes
    Array of Weight Object
    Weights of the pods in the StatefulSet.
    Table 5 Weight data structure
    Mandatory
    Type
    weight
    Yes
    String
    Traffic weight allocated to a specified pod.
    podIndexes
    Yes
    Array of Integer
    List of pod indexes that use this weight. For example, [1] in the example indicates pod test-state-1.
  3. Create the Service.
    kubectl create -f service-test.yaml
    If information similar to the following is displayed, the Service has been created:
    service/service-test created
Verifying Weight Settings
  2. In the navigation pane, choose Services and Ingresses. Locate the row that contains the created Service and click the load balancer name to go to the ELB console.
  3. Switch to the Listeners tab page. Check whether a supplementary network interface is bound to the listener's backend server and whether the weight meets expectations.
Helpful Links
When cross-cluster backend is enabled (kubernetes.io/elb.multicluster: 'true'), use kubernetes.io/elb.custom-backend-weights instead of kubernetes.io/elb.multicluster-loadbalancer-weight to configure weights for backend pods of StatefulSets. All other configurations remain unchanged. For details about the applications and configurations of cross-cluster backend servers, see Configuring Multiple Cross-Cluster Backend Servers for a LoadBalancer Service.
The StatefulSet settings in kubernetes.io/elb.custom-backend-weights apply only to a Service's backend servers. Therefore, when using cross-cluster backend servers, add both kubernetes.io/elb.multicluster and kubernetes.io/elb.custom-backend-weights for Services in each cluster.
