Help Center/ Cloud Container Engine/ User Guide/ Networking/ Services/ LoadBalancer/ Network and Backend Configuration/ Configuring Multiple Cross-Cluster Backend Servers for a LoadBalancer Service
Updated on 2026-08-13 GMT+08:00
You can configure cross-cluster backend servers for a listener that is associated with a LoadBalancer Service. The following describe the supported scenarios and how to enable cross-cluster access:
  • Pods in different clusters can be configured as backend servers for the same load balancer listener. To achieve this, create a Service in each cluster, associate all Services with the same load balancer, and specify the same external port. The backend servers of each Service are then added to the same listener. This load balancer forwards traffic to pods in different clusters, and the weights of the clusters for receiving traffic are configurable. For details, see Adding Multiple Cross-Cluster Backend Servers That Are in the Same VPC to a Load Balancer.
    Figure 1 Configuring some cross-cluster backend servers for the same load balancer
  • Pods in a CCE cluster and ECSs can be configured as backend servers for the same load balancer listener. To achieve this, associate the Service with an existing listener, then add both the pods and ECSs to that listener's backend server group. Traffic is forwarded to the CCE pods or the ECSs accordingly. For details, see Adding Multiple Cluster Backend Servers and ECSs That Are in the Same VPC to a Load Balancer Listener.
    Figure 2 Configuring some ECSs and backend servers in a cluster for the same load balancer
In a cluster, there can be several backend servers. When ELB traffic is directed to a cluster, the backend servers within the same cluster have equal weights. For details, see Figure 1.
The rules for configuring the weights of backend servers in the same clusters are as follows:
  • In ELB passthrough networking where a dedicated load balancer is used in a CCE Turbo cluster, the ELB backend server is the target pod associated with the Service. In this case, the weight of each target pod is calculated by dividing the cluster traffic weight by the total number of target pods and rounding up the value.
  • In non-ELB passthrough networking (in CCE Turbo clusters using a shared load balancer or in CCE standard clusters), the ELB backend server is the node hosting the target pod associated with the Service. To calculate each node's weight in this scenario, use the following formula and round up the result: Node weight = (Cluster traffic weight/Total target pods) × Target pods on the node.
  • This feature works only on the Services created using an existing load balancer, but not on those created using an automatically created load balancer.
  • This feature works only on the Services created using a YAML file, not through the console.
  • Cross-cluster access Services connect to the same listener. The backend server group under the listener uses the configurations (such as the health check configuration) of the first Service created among the clusters.
  • When Services in different clusters connect to the same listener, the cross-cluster access must be configured for all Services.
Precautions
  • By default, deleting a cross-cluster Service only deletes the ELB backend server in the current cluster. You can also configure a cascading deletion policy to delete the load balancer resources. Note that when you configure a cascading deletion policy, deleting a Service or cluster will forcibly reclaim the listener and backend server group.
  • When using a load balancer for cross-cluster access, ensure cross-cluster access is enabled for all the Services bound to the load balancer. Otherwise, the backend server group of the load balancer may be overwritten.
  • After a cross-cluster access Service is created, CCE automatically adds the kubernetes.io/elb.listener-port-ranges-auto-generated or kubernetes.io/elb.mark, and kubernetes.io/elb.listener-port annotations for internal status management. Do not manually specify, modify, or delete these annotations. Doing so will cause load balancer resource reclamation to fail.
The cluster version must be v1.23.18-r0, v1.25.13-r0, v1.27.10-r0, v1.28.8-r0, v1.29.4-r0, v1.30.1-r0, or later.
If cluster A and cluster B are both located in the same VPC and there is already a load balancer, configure cross-cluster access with the following settings: Set the weight of the Service in cluster A to 80 and that of the Service in cluster B to 20 for traffic distribution. To do so, perform the following operations:
  1. Create a Service in cluster A.
    apiVersion: v1
    kind: Service
      annotations:
        kubernetes.io/elb.id: 5083f225-9bf8-48fa-9c8b-67bd9693c4c0   # Load balancer ID. Replace it with the actual value.
        kubernetes.io/elb.class: performance  # Load balancer type
        kubernetes.io/elb.multicluster: 'true'  # Enable cross-cluster access for the Service.
        kubernetes.io/elb.multicluster-loadbalancer-weight: '80'  # Weight of the cluster Service for receiving traffic
        kubernetes.io/elb.multicluster-resource-recycle-policy: member-only  # Policy for deleting load balancer resources. The default value is member-only, indicating that only the backend servers of the load balancer are deleted when the Service is deleted. The cascade policy forcibly reclaims the ELB listener and all associated resources.
      ports:
      - name: service0
        port: 80   # ELB listener port
        protocol: TCP
        targetPort: 80
      selector:
        app: nginx
      type: LoadBalancer
    Table 1 Key annotation parameters
    Mandatory
    Type
    Yes
    String
    Load balancer ID. This parameter works only with existing load balancers. This parameter cannot be modified after the Service is created.
    Yes
    String
    Load balancer type. The value can be union or performance. This parameter cannot be modified after the Service is created.
    Yes
    String
    Value true indicates cross-cluster Service access is enabled.
    No
    String
    Weight of the traffic received by the cluster Service. The value ranges from 0 to 100. A larger value indicates more traffic distributed. If this annotation is not specified, the default weight is 1.
    Deleting kubernetes.io/elb.multicluster-loadbalancer-weight will not change the configured weight.
    Yes
    String
    Policy for deleting ELB resources. The default value of this parameter is member-only.
    • member-only: Only the backend servers of the load balancer will be deleted when the Service is deleted.
    • cascade: The ELB listener and all associated resources are forcibly reclaimed when the Service is deleted. Configure this policy only on the first Service that was created.
  2. Create a Service in cluster B.
    apiVersion: v1
    kind: Service
      annotations:
        kubernetes.io/elb.multicluster-loadbalancer-weight: '20'  # Weight of the cluster Service for receiving traffic
      ports:
      - name: service0
        port: 80   # The ELB listener port, which must match the Service port in cluster A
        protocol: TCP
        targetPort: 80
      selector:
        app: nginx
      type: LoadBalancer
Adding Multiple Cross-Cluster Backend Servers That Are in Different VPCs to a Load Balancer
  • The cluster version must be v1.23.18-r0, v1.25.13-r0, v1.27.10-r0, v1.28.8-r0, v1.29.4-r0, v1.30.1-r0, or later.
  • Only existing dedicated load balancers can be used.
  • IP as a Backend must be enabled on the ELB console. For details, see Adding Backend Servers in a Different VPC from a Backend Server Group.
  • The VPC CIDR blocks cannot conflict with each other, and the VPCs are connected through VPC peering. For details, see VPC Peering Connection.
  • For a cluster that is not in the same VPC as the load balancer, the cluster node security group (which is a network interface security group for Cloud Native Network 2.0) must allow the traffic with the source IP addresses in the VPC CIDR blocks of the load balancer to pass.
  • When a cross-VPC backend server is added to a load balancer, the security group of the cluster must allow the access from the backend CIDR blocks of the load balancer, and UDP listeners are not allowed. For details, see Restrictions and Limitations.
If cluster A and cluster B are located in different VPCs and there is already a load balancer in one of the VPCs, configure cross-cluster access.
    apiVersion: v1
    kind: Service
      annotations:
        kubernetes.io/elb.multivpc: 'true'
      ports:
      - name: service0
        protocol: TCP
        targetPort: 80
      selector:
        app: nginx
      type: LoadBalancer
    Table 2 Key annotation parameters
    Mandatory
    Type
    Yes
    String
    Yes
    String
    Load balancer type. Only dedicated load balancers can be used, meaning that the value of this parameter must be performance. This parameter cannot be modified after the Service is created.
    Yes
    String
    No
    String
    Value true indicates cross-cluster access in different VPCs is enabled. This function is available only if kubernetes.io/elb.multicluster is set to true. This parameter cannot be modified after the Service is created.
    No
    String
    Yes
    String
    apiVersion: v1
    kind: Service
      annotations:
      ports:
      - name: service0
        protocol: TCP
        targetPort: 80
      selector:
        app: nginx
      type: LoadBalancer
If cluster A and two ECSs are both located in the same VPC and there is already a load balancer, configure access by setting the weight of the Service in cluster A to 80 and that of each ECS to 20 for traffic distribution. To do so, perform the following operations:
  1. On the ELB console, create a listener (for example, frontend port 80) and a backend server group, manually add the ECSs to the group, and set the total weight to 20. For details, see Adding Backend Servers in the Same VPC as a Backend Server Group.
  2. Create a Service in cluster A, connect the Service to the created listener, and set the Service weight to 80.
    apiVersion: v1
    kind: Service
      annotations:
      ports:
      - name: service0
        port: 80   # Listener port 80 for connecting to the load balancer
        protocol: TCP
        targetPort: 80
      selector:
        app: nginx
      type: LoadBalancer
    Table 3 Key annotation parameters
    Mandatory
    Type
    Yes
    String
    Yes
    String
    Yes
    String
    No
    String
    Weight of the cluster Service for receiving traffic. If this annotation is not specified, the default weight is 1.
    Yes
    String
  3. Check whether the pods have been added to the ELB backend server group and whether the weight is 80.
Helpful Links
When cross-cluster backend is enabled (kubernetes.io/elb.multicluster: 'true'), use kubernetes.io/elb.custom-backend-weights instead of kubernetes.io/elb.multicluster-loadbalancer-weight to configure weights for backend pods of StatefulSets. All other configurations remain unchanged. For details, see Configuring Weights for StatefulSet Backend Pods in a LoadBalancer Service.
The StatefulSet settings in kubernetes.io/elb.custom-backend-weights apply only to a Service's backend servers. Therefore, when using cross-cluster backend servers, add both kubernetes.io/elb.multicluster and kubernetes.io/elb.custom-backend-weights for Services in each cluster.
