Updated on 2026-09-21 GMT+08:00
(kubectl) Creating a StatefulSet Mounted with an SFS Turbo Volume
CCE allows you to use an existing SFS Turbo volume to create a StatefulSet.
Notes and Constraints
The following configuration example applies to clusters of Kubernetes 1.13 or earlier.
  1. Create an SFS Turbo volume and record the volume name.
  2. Use kubectl to connect to the cluster. For details, see Accessing a Cluster Using kubectl.
  3. Create a YAML file for creating the workload. Assume that the file name is efs-statefulset-example.yaml.
    touch efs-statefulset-example.yaml
    vi efs-statefulset-example.yaml
    Example YAML:
    apiVersion: apps/v1
    kind: StatefulSet
      namespace: default
      replicas: 1
      selector:
        matchLabels:
          app: efs-statefulset-example
      template:
          annotations:
            metrics.alpha.kubernetes.io/custom-endpoints: '[{"api":"","path":"","port":"","names":""}]'
            pod.alpha.kubernetes.io/initialized: 'true'
          labels:
          containers:
            - image: 'nginx:1.0.0'
              resources:
                requests: {}
                limits: {}
              env:
                - name: PAAS_APP_NAME
                  value: efs-statefulset-example
                - name: PAAS_NAMESPACE
                  value: default
                - name: PAAS_PROJECT_ID
                  value: b18296881cc34f929baa8b9e95abf88b
              volumeMounts:
                - name: efs-statefulset-example
                  mountPath: /tmp
                  readOnly: false
                  subPath: ''
          imagePullSecrets:
            - name: default-secret
          terminationGracePeriodSeconds: 30
          volumes:
            - persistentVolumeClaim:
                claimName: cce-efs-import-jnr481gm-3y5o
          affinity: {}
          tolerations:
            - key: node.kubernetes.io/not-ready
              operator: Exists
              effect: NoExecute
              tolerationSeconds: 300
            - key: node.kubernetes.io/unreachable
              operator: Exists
              effect: NoExecute
      podManagementPolicy: OrderedReady
      serviceName: test
      updateStrategy:
        type: RollingUpdate
    Table 1 Key parameters
    replicas
    Number of pods.
    name
    Name of the created workload.
    Image used by the workload.
    mountPath
    Mount path in the container.
    serviceName
    Service corresponding to the workload. For details about how to create a Service, see Creating a StatefulSet.
    claimName
    Name of an existing PVC.
    spec.template.spec.containers.volumeMounts.name and spec.template.spec.volumes.name must be consistent because they have a mapping relationship.
  4. Create the StatefulSet.
    kubectl create -f efs-statefulset-example.yaml
