Updated on 2026-09-21 GMT+08:00
(kubectl) Creating a Deployment Mounted with an SFS Turbo Volume
After an SFS Turbo volume is created or imported to CCE, you can mount the volume to a workload.
Notes and Constraints
The following configuration example applies to clusters of Kubernetes 1.13 or earlier.
  1. Use kubectl to connect to the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Run the following commands to configure the efs-deployment-example.yaml file, which is used to create a Deployment:
    touch efs-deployment-example.yaml
    vi efs-deployment-example.yaml
    Example of mounting an SFS Turbo volume to a Deployment (PVC-based, shared volume):
    apiVersion: apps/v1
    kind: Deployment
      name: efs-deployment-example                                # Workload name
      namespace: default
      replicas: 1
      selector:
        matchLabels:
          app: efs-deployment-example
      template:
          labels:
          containers:
          - image: nginx
            volumeMounts:
            - mountPath: /tmp                                # Mount path
          restartPolicy: Always
          imagePullSecrets:
            - name: default-secret
          volumes:
          - name: pvc-efs-example
            persistentVolumeClaim:
              claimName: pvc-sfs-auto-example                # PVC name
    Table 1 Key parameters
    name
    Name of the created Deployment.
    app
    Name of the application running in the Deployment.
    mountPath
    Mount path in the container. In this example, the mount path is /tmp.
    spec.template.spec.containers.volumeMounts.name and spec.template.spec.volumes.name must be consistent because they have a mapping relationship.
  3. Run the following command to create the pod:
    kubectl create -f efs-deployment-example.yaml
    After the creation is complete, choose Storage > SFS Turbo on the CCE console and click the PVC name. On the PVC details page, you can view the binding relationship between SFS Turbo and PVC.
