Automatically Creating an SFS Volume Through kubectl
Currently, SFS file systems are sold out and PVCs cannot be automatically created using the storage class.
Notes and Constraints
The following configuration example applies to clusters of Kubernetes 1.13 or earlier.
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Run the following commands to configure the pvc-sfs-auto-example.yaml file, which is used to create a PVC.
touch pvc-sfs-auto-example.yaml
vi pvc-sfs-auto-example.yaml
Example YAML file:apiVersion: v1 kind: PersistentVolumeClaim metadata: annotations: volume.beta.kubernetes.io/storage-class: nfs-rw name: pvc-sfs-auto-example namespace: default spec: accessModes: - ReadWriteMany resources: requests: storage: 10GiTable 1 Key parameters Parameter
File storage class. Currently, the standard file protocol type (nfs-rw) is supported.
name
Name of the PVC to be created.
accessModes
Only ReadWriteMany is supported. ReadWriteOnce is not supported.
storage
Storage capacity, in Gi.
- Run the following command to create a PVC:
kubectl create -f pvc-sfs-auto-example.yaml
After the command is executed, a file system is created in the VPC to which the cluster belongs. Choose Storage > SFS on the CCE console or log in to the SFS console to view the file system.
