Node Readiness
Check Items
Check whether the nodes in the cluster are ready.
- Scenario 1: The nodes are in the unavailable status.
Log in to the CCE console and click the cluster name to access the cluster console. Choose Nodes in the navigation pane and filter out unavailable nodes, rectify the faults by referring to the suggestions provided by the console, and check again.
- Scenario 2: The displayed node status is inconsistent with the actual status.
The possible causes are as follows:
- The node status is normal on the Nodes tab, but the check result shows that the node is not ready. Check again.
- The node is not found on the Nodes tab, but the check result shows that the node is in the cluster. Contact technical support.
