Help Center/ Cloud Container Engine/ User Guide/ Clusters/ Upgrade Management/ Troubleshooting for Pre-upgrade Check Exceptions/ ASM Version
Updated on 2026-09-21 GMT+08:00
ASM Version
Check Items
Check the following items:
- Check whether ASM is used by the cluster.
- Check whether the current ASM version supports the target cluster version.
- Upgrade ASM and then upgrade the cluster. The following table lists the adaptation rules between ASM and cluster versions.
Table 1 Adaptation rules between ASM and cluster versions ASM Version
Cluster Version
1.3
v1.13, v1.15, v1.17, or v1.19
1.6
v1.15 or v1.17
1.8
v1.15, v1.17, v1.19, or v1.21
1.13
v1.21 or v1.23
1.15
v1.21, v1.23, v1.25, v1.27, or v1.28
1.18
v1.25, v1.27, v1.28, v1.29, v1.30, v1.31, v1.32, or v1.34
- If ASM is not required, delete it before the upgrade. After the upgrade, the cluster cannot be bound to ASM that does not match the table. For example, a cluster v1.21 and ASM v1.8 are used. If you want to upgrade the cluster to v1.25, upgrade ASM to v1.15 first.
- If you have not installed ASM, check whether the open-source Istio is installed in the cluster. If it is, check whether the current Istio version is compatible with the target cluster version. If they are compatible, skip this step and perform the check again. If they are not compatible, upgrade the Istio version and then upgrade the cluster.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
